Hi all,
Im looking for a conical stand alone horn for a JBL 2452, but I have some questions that im looking to answer before I go any further. Im interested in the JMLC 350hz and ferguson horns that jzagaja sells, but I cannot find any graphs for FR or other data of the driver I have (or similar 24xx drivers) on this kind of horn. The exit angle of the driver is 10 degrees (so im told), what would the throat angle be on the jmlc horn? Does it matter? what is the T factor of the jmlc 350? The 2452 is a 1.5" driver, Jzagaja only lists 1.4" not 1.5" as available mountings- Does he do a 1.5"? http://www.autotech.pl/pdf/audio_en.pdf Any help apperciated! Thanks |
#2 |
bump!
#3 |
JMLC-350 can be cut to any throat. With 1.5" resulting throat angle is 7.8deg. Only modern "waveguide" drivers have significantly larger throat angle.
#4 |
The 2452SL is throatless ("optimize aperture" design), so a 0° angle would be ideal, but I guess any small exit angle will do.
http://www.jblpro.com/catalog/suppor...=298&doctype=3 |
#5 |
thanks guys,
Obviously 0 degrees is ideal, but I cant see what other option I have unless I make it myself. Is there a way around this? has anyone tried building up the first few mm of the horn with putty to graduate the transition between the driver and horn angles? |
#6 | |
Use a cosh flare to match the tangent angle [Am] of the horn at the throat radius Rm = 1" Formula to use to determin the profile: Rm = Rt*cosh(m*Lm)= 1.0" Tan(Am)= m*Rt*sinh(m*Lm) Lm - Length of adapter Rt - Radius (ordinal) where driver an adapter join = .75" m - Flare coefficient of the adapter (Adapter Fc <= Horn Fc) Regards, WHG Last edited by whgeiger; 11th September 2011 at 12:52 PM. |
#7 |
Hi whgeiger,
Im having difficulty understanding your post. The driver is 1.5", so are you suggesting getting a 2" version of the horn and making an adapter piece that goes between the horn and driver to make a tighter angle transition? jzagaja, what is the final throat angle on the 2" version? Last edited by lbstyling; 11th September 2011 at 03:41 PM. |
#8 | |
Rt = 0.75", At = 0.00 deg. To Horn: Rm = 1.00", Am = (from jzagaja) You adjust m & Lm to get a matching Rm & Am for the adapter. If you want a design, once [Am] is known, I will send you a drawing. Regards, WHG |
#9 |
Sorry for mistake - throat angle is constant 7 degrees up to 2".
#10 |
| OB bass with JBL horn? | NYCOne | Multi-Way | 7 | 4th September 2011 07:57 AM |
| Scan-Speak 10F JMLC horn combo - large dip troubleshooting | Defo | Multi-Way | 21 | 11th August 2010 09:14 AM |
| Horn enclosures w/ JBL 2226 and JBL 375. | burtcheca | Swap Meet | 0 | 2nd August 2010 01:21 PM |
| Backchamber in a JMLC horn | Defo | Multi-Way | 6 | 10th July 2010 08:46 AM |
| Newbie JBL horn question | markzb | Multi-Way | 14 | 19th July 2004 12:16 AM |
| Page generated in 0.10728 seconds (81.69% PHP - 18.31% MySQL) with 11 queries |
