The is the impedance curve I got in LSPCad for 2 Vifa TC11s in parallel - see any problems?
My amp should should be able to handle it as it is: 115W 8 ohm 160w 4 ohm 175w 2 ohm |
#2 |
ur amp is 2ohm capable?
nice!
#3 |
High impedance is no problem for an amp. If it is an amp designed to give out 8 ohms, an impedance peak well over 8 ohms will give it no problems at all.
Low impedance is the problem. I see that your lowest impedance is about 2.8 ohms. An amp rated for 2 ohms will handle it with ease. It is low impedance that causes the problems. High impedance is a piece of cake.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#4 |
I think the graph is a bit misleading as I believe the impedance would start to rise from 400Hz on based on the Vifa's graph. I can't measure this. Seems similar to the impedance for the LR speaker in chapter 12 in the Loudspeaker Design Cookbook - bottoms at 3 Ohms. Probably classed as a 4 Ohm speaker.
The amp manual is interesting as it states "if you use one centre speaker, the impedance of the speaker must be 4 ohm or higher, if you use 2 centre speakers, the impedance of each speaker must be 2 ohm or higher". I thought that with 2 speakers you would need 8 ohms or higher. |
#5 |
They're probably assuming that you'll wire them in series.
#6 |
I think you will be fine. The impedance will be a bit low, but not much power will be going into these TC11's-they can't handle that much. Really, only a couple of watts at the low end before they start to distort. See my impedance curve and comments. I suspect your impedance will be around 2.5 ohms.
Link to Vifa TC11 project |
#7 |
Thanks Mark.
These will not see much bass below 80Hz as they are setup for rear speaker duties with the speakers set to small. Since the 2 drivers are in parallel, this will halve the cone excursion. The box is tuned to 66Hz which helps some more. |
| Impedance Curve | jwatts | Car Audio | 2 | 2nd December 2004 08:33 AM |
| Impedance Curve | jwatts | Multi-Way | 4 | 22nd November 2004 05:45 PM |
| Help: SS Impedance Curve | Jay | Multi-Way | 4 | 21st August 2003 07:56 AM |
| Impedance curve shape | Raka | Multi-Way | 4 | 8th November 2002 12:28 AM |
| Impedance curve | masterp2 | Multi-Way | 8 | 3rd March 2002 12:34 PM |
| Page generated in 0.08294 seconds (80.09% PHP - 19.91% MySQL) with 11 queries |
