#91 | |
Either way, you're probably right!" Henry Ford
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#92 | |
#93 |
Skill saw will work in a pinch. Heck even a jig saw if you are patient enough. It is a fairly simple box when you look at it correctly. No extreme angles or anything hard like that. I tried to make it as simple as possible with the best performance possible.
Mark |
#94 | |
The way I envision myself taking on a project like this, mostly what I need is tape measure, pencil, good instructions, and lots of patience. To me the difficult part about speaker building (or shall I say the part I need to learn the most), is what kind of equipment to get to measure the sonic responces, and then how to interpret the data, use the data to make appropriate adjustments using crossovers and whatnot. I think I have much to learn -With this kit, the design part is done, just follow the directions to the proven design. The woodworking is a much lesser challenge to me. Last edited by AlexQS; 25th January 2012 at 02:40 AM. |
#95 |
Go for it buddy. You have never heard the likes of what this box will produce. Few people have. It is a real eye opener. And most importantly ear opener.
Mark |
#96 |
Jmorken, your unity looks fantastic! First rate work. I would like to build a horn that's basically a slightly longer version of your design that uses two Eminence alpha 6 mids.
Can anyone draw up what I have attached in google sketchup, so that I can know the dimensions and miter angles? I have a shop full of tools and lots of woodworking experience, but I haven't yet figured out sketchup. Maybe there's a simple way to modify jmorken's design that he posted here? I have attached it here as well. Suitable midrange cone, for bandpass mid in Unity horn. Thanks very much, John |
#97 | |
But these parameters are unfortunately impossible to build. For instance, the throat chamber volume and area is set to zero. Which means there is no throat chamber. And that's perfectly valid, as long as the area where the woofers enter the horn is large enough. But it's not - it's set to fifty square centimeters, which is a small fraction of the woofer's size. That's the reason that the very very small woofers start to look attractive for a unity horn. You can squeeze a pile of them very close to the throat, and get the surface area of a much larger woofer, basically subdivided over an array of small drivers. Taken to the extreme, you see the layered combiner that Danley has been talking about lately, with sixty four drivers at the apex of a horn(!) |
#98 | |
As far as the woofer offset, you're also right about the model. However, as I'm only using two drivers, I can extend a shelf off the sides of the horn to allow for overhang, much as Paul Spencer has drawn out on his blog, as well as offset the entry tap (great idea, Paul!). Finally, I don't necessarily plan to have the entry tap at 7 cm from the apex- I'll likely move it closer but will experiment w/ placement via removable wooden plates, onto which the woofers are mounted. As long as the woofer is close enough, the high end roll off won't happen too soon (I've played around w/ hornresp a lot, changing up the L1L2 and S2 to see what happens). I'll likely use a BMW 4550 and a miniDSP for this project. I'm shooting for a fair amount of flat FR overlap between the mids and the CD. If I get it, I'll bisect the overlap for my XO frequency, and use the minidsp to adjust delay and individual driver EQ.... an analog purist I'm most certainly not! Yeah, this may make an unnecessary pile of sawdust, but I've always been more of a trial and error guy than a modeler. Anyway, I'm starting to learn sketchup on my own, and I'll start a thread when (if!) I get everything together. John |
#99 | |
WinISD is completely unsuitable for simulating them. Hornresp and Akabak are pretty darn good, but they still miss a few variables because they don't simulate the device in three dimensions. I really don't mean to sound like a wet blanket, but I've built a dozen of these, and I had to waste a lot of time before I got results that were even halfway acceptable. If anyone's curious to follow my latest one, I am documenting it here: DIYMA Car Audio Forum - View Single Post - Anyone Want Some HLCDs? ![]() |
| Tapped Horn Feeding A Unity Horn | Patrick Bateman | Multi-Way | 20 | 4th September 2010 01:27 PM |
| Another Unity Horn | Patrick Bateman | Multi-Way | 324 | 16th December 2009 02:15 PM |
| Not Another Unity Horn | Patrick Bateman | Multi-Way | 29 | 26th July 2009 04:17 AM |
| Page generated in 0.12471 seconds (80.87% PHP - 19.13% MySQL) with 11 queries |
