Hi all
I'm going to go ahead and build this design from Troel's site: Peerless HDS 134 + I've decided (after advice on here - thanks) to plump for the XT25TGG30-04 tweeter and have started putting together some cabinets. My question: I look at the crossover schematic and see that the bass driver and tweeter have their own individual schemas for their respective components. In my inexperienced head I can only see this as needing a biwirable terminal plate as opposed to a terminal plate with a single set of binding posts. Troels' site shows the cabinet as having only one set of terminals and I was wondering how in practice this is done: Crossover components for each driver mounted on two boards with a + and - wire from each board attached to the respective + or - terminal? I wanted to get this straight in my mind before I order the components. Sorry for the noob question (unfortunately I'm full of them). Maybe I should take up stamp collecting instead. Cheers Nick |
#2 |
Did it Himself
Simply join the inputs to the two halves together at the cabinet terminals.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Audio Engineer
To use a single set of terminals you simply wire both the grounds together and both the positive inputs together. This is what you would do back at the amplifier if you bi wire anyway the only difference is the bass and treble currents share the same wire impedance. Regards, Andy |
#4 |
Thanks to you both. I'm pleased that my understanding was correct.
Richard - I followed your link. Interesting site, I'll have a proper read through when I've more time. Andy - the biwiring analogy at the back of the amp makes perfect sense. I've done that 100's of times and didn't make the jump in my mind that the principle was the same - doh! |
| Require advise on tda2050 this schematic | pra3718 | Chip Amps | 39 | 26th March 2012 03:57 PM |
| Would it be possible to build a combined AMP and DAC like this? (Please advise!) | Pipps | Digital Line Level | 8 | 23rd December 2010 06:15 PM |
| Advise on crossover for tweeters | Nicola | Multi-Way | 8 | 27th May 2010 10:20 PM |
| advise on 2nd build | Mindcrime | Multi-Way | 2 | 12th January 2009 12:58 PM |
| Need advise on speaker build | captaink | Multi-Way | 4 | 15th September 2008 10:24 AM |
| Page generated in 0.07125 seconds (84.14% PHP - 15.86% MySQL) with 10 queries |
