El Cuerno
El Cuerno
Old 28th October 2011, 11:29 AM   #11
erjee is offline erjee  Netherlands
Originally Posted by gedlee View Post
Very respectable work.
Thanks!
Originally Posted by 454Casull View Post
I see you like your bass!
There is a solid and tight foundation, for sure, but it is not too much (from my perspective as a bass player )
Originally Posted by ttan98 View Post
erjee,
Nice work, at the same time the system costs a fraction of an equivalent commercial system. Should sound very good even without listening to it.
Thanks! Whenever you are in the netherlands, come by for a listen
Old 29th October 2011, 02:01 PM   #12
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
El Cuerno
erjee, can you give any more details on how you did the foam and containerboard? Is it just a strip of foam contained by containerboard?
Old 29th October 2011, 02:56 PM   #13
Yes, in combination with a lot of ducktape (and a couple of screws now), that's all
Combined with the large magnet of the midwoofer this creates a fairly narrow, well damped slit. The lightgrey foam is Visaton NG42 (Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories) and the dark grey stuf is some unbranded acoustic foam to fill-up the remaining gap.
Old 29th October 2011, 03:07 PM   #14
454Casull is offline 454Casull  Canada
Is the foam fire-retardant? I expect that the voice coil heats up significantly when played loudly.
Old 29th October 2011, 04:21 PM   #15
As far as I know it is not fire-retardant. The foam is not positioned close to the voicecoil, it only covers the ribs of the 10PS26 so there is some volume of air.
But I won't expect problems for normal home-use. My Hypex amplifier can only deliver 100W/8Ohm, which is just enough to deliver peaks at 200 Hz of 105 dB at listening position, and I never felt a change in temperature of the magnet after playing loud. I estimate that the average power in such a situation would be much lower, maybe 10 W, because the sensitivity at 500 Hz is 5 dB better and the average power level for music is much lower than the peak level.
Old 28th July 2012, 07:53 AM   #16
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Hi erjee, very nice project! Do you by any chance have polars of the "mid" alone? with no filter..
thanks
Old 14th August 2012, 06:26 AM   #17
thanks
Hi SumacSK,
Thanks! I found a measurement of the mid alone:
This is the raw response without any eq.
Old 17th November 2012, 10:50 AM   #18
Beau is offline Beau
Awesome work!! Any chance of a closeup or drawing of the rear? Ive been wanting to do a very similar setup with a 15" mid.
Old 19th November 2012, 04:42 PM   #19
Thanks!
I have no access now to a high resolution photo of the back now, but the construction is as simple as you can see in the photo. The 10" midwoofer has a large magnet, the volume between the magnet/frame and cardboard cylinder is filled with foam. I think the cardboard construction is somewhat lossy so this might contribute in a positive way.
If the construction is still unclear to you, please say so, I can make a drawing for you.
Old 19th November 2012, 11:22 PM   #20
Got it thanks. Keen to try something similar soon.
El CuernoHide this!Advertise here!
el dipole CosmoA Subwoofers 5 3rd September 2009 08:06 AM
el pipe-o mantisory Subwoofers 5 2nd February 2009 04:51 PM
WTB: Elantec EL-2008CT or EL-2009CT buffers KT Swap Meet 0 5th January 2006 05:08 PM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 09:00 AM
Greetings from EL. madflower Introductions 1 5th June 2005 12:36 AM
