The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter - Page 2 - diyAudio
Old 4th September 2011, 09:49 PM   #11
Apex Jr is offline Apex Jr  United States
Dave....
I still have quite a few of these in stock, say 4000 still in stock
and am still offering the DIY Audio 1/2 off sale at .50ea.
And on a side note I still know I owe you some, so will include
in your next order....
Steve
Old 4th September 2011, 10:09 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Steve,
I am never worried about being taken care of when it comes to doing business with you... probably need some more panelmount RCAs next, Daniel is smoking thru them
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th September 2011, 05:03 PM   #13
River757 is offline River757  United States
River757's Avatar
Originally Posted by sreten View Post
Some have experimented with opening up the pinhole, for tuning.
Can that pinhole make a significant difference as far as sound quality? Because the other domes I have seen with lenses (phase plugs?) that include a hole, that hole is much larger than this tweeter's pinhole.
Old 6th September 2011, 05:27 PM   #14
diyAudio Member RIP
One would assume the pinhole makes next to no difference, its styling.
I remember a UK kit speaker that claimed the provided tweeters had
an optimised modified opened up central hole, easy to say, but no
real hard evidence I recall that this was the case. Your right IMO
to have an effect the hole must be a lot larger. There again there
are fine tweeters with no central hole at all, so what gives ?
I don't know, here only measurements tell the truth.
rgds, sreten.
Old 7th September 2011, 06:41 PM   #15
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Mordaunt short have also used this style of tweeter I think before the last time they went bankrupt (they have gone bust a few times). In the speaker my friend owns they are are combined with an 8" ported woofer in a ~35L cab and work quite well.
CHR-70+Subs
Old 7th July 2013, 03:17 AM   #16
cT equals piD is offline cT equals piD  United States
How about a Foster 9324 tweeter? It looks to be a polycarbonate, it has a lens/ waveguide with three plastic arms holding a small cylinder above a black diaphragm.
In terms of what kind of dispersion it has, is all of the diaphragm that is visible the moving surface? I'm seeking a tweeter that would start beaming at about 10 kHz, and am wondering if the Foster would fit the bill.
Pete
Old 8th July 2013, 12:45 AM   #17
Default Foster 9324
Removing the faceplate from the motor and diaphragm, the polycarbonate starts out first as a cone (concavity), then at the center is a small dome. The outside diameter of the polycarbonate is about 7/8" (22 mm).
Also I was wondering if the waveguide affects dispersion.
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeterHide this!Advertise here!
Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout tcpip Solid State 128 23rd September 2013 04:45 PM
31 Band Equalizer "the t.eq" "TQ-60" schematic wanted tiefbassuebertr Solid State 2 29th March 2010 03:45 PM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 07:20 AM
Copyright ©1999-2017 diyAudio
