Wavecor 6.5" WF160WA02
Old 8th January 2012, 09:44 AM   #21
PeteMcK is offline PeteMcK
finally got these into more sensible 24L boxes & hooked up for a listen using my Peerless 5" mids crossed over at ~ 500Hz. The boxes are yet to be tuned pending a bit more burn-in, but my above comments are confirmed, plenty of nice sounding low end.
That said, they're still a 6" driver, & lose it a bit when really pumped. Ideal for computer monitors, bookshelfs & perhaps a small TL.... or even an 'Elsinore' clone But now I'm hankering for a pair of 15"ers/side ...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 8th January 2012, 10:44 AM   #22
jerome69 is offline jerome69  France
jerome69's Avatar
A pair of 10" can do the job
Old 8th January 2012, 02:47 PM   #23
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Originally Posted by PeteMcK View Post
finally got these into more sensible 24L boxes.... The boxes are yet to be tuned ..That said, they're still a 6" driver, & lose it a bit when really pumped.
some new measurements:
Fs 63.5 (WTF?), Qt .53, Qe .58, Qm 5.32, Vas 12L.....
at Fs 64Hz how low can it go?
Originally Posted by jerome69 View Post
Edit : Wavecor has a new range of 7" driver nomex cone and paper cone with a new basket. They seem to be serious challengers to the ER18.
Which 7"? The WF182 "Balanced Drive" unit?
...still looking for the holy grail.
Old 8th January 2012, 08:33 PM   #24
re:'A pair of 10" can do the job ' - yeah, but 2x 15" looks so much more macho..
re:'at Fs 64Hz how low can it go?' - yes, I was surprised too, but I've got to measure the specs again after a bit more burn in (the box is tuned to ~ 39 Hz at present, it'll probably end up being in the low 40s to tighten up the bottom end a bit)
Old 19th September 2012, 02:52 AM   #25
rhythmsandy is offline rhythmsandy
i got these drivers in terms of bass extension its complete disappointment... Its not like the scanspeak carbon cones where you get the entire low sweetness..
I have designed this and sold to few customers all complain about the bass extension..
Mids have problems... alot of problems infact the only positive thing about this thing is it has details... alot of details... I hardly see any scanspeak or other driver can do this kind of fast response but it eats away all the sweetness in sound... I would rather prefer to use this driver as a midrange and sure cant fit in 2 way and satisfy more customers..
People who like upper mids and highs can choose this driver.
There is a serious over tone in the freq around 1khz there is some sort of breakup and uneven curve... you can even see this on the graph...
they need to re engineer this product not sufficent and the Fs is very bad for such a big driver...
so like I said technically this could be a very good mid than a mid bass...
people who say its good low bass but no... it doesnt work on that lines...
Old 19th September 2012, 03:47 AM   #26
rhythmsandy, what size box & what tuning are you using?
re: 'Its not like the scanspeak carbon cones where you get the entire low sweetness..' well, they're a LOT cheaper, I wouldn't expect them to be in the same ballpark....
Old 19th September 2012, 03:54 AM   #27
height 13
width 9.5 inch
depth 10 inch
all external dimensions
two ports with 2 inch diameter 6 inch length..
Old 19th September 2012, 04:52 AM   #28
so ~17L tuned to ~ 59Hz, not surprising you're getting no low bass out of that,
you'd need a box nearly double that size & tuned to the low 40s
Old 19th September 2012, 05:02 AM   #29
what about this box?13.04 x 20.01 x 8.39
internal volume = .872 Cubic foot
Port tuned frequency 49.65Hz
Port diameter: 4.02 inches
Port Length : 12.66 inches. Matched to the accuracy of 97%
Old 19th September 2012, 05:22 AM   #30
that'll be better, but it'll give a bass rise at the low end & still fall of rapidly below ~ 50 Hz. Tuning a bit lower might be better
Wavecor 6.5" WF160WA02Hide this!Advertise here!
Wavecor 2.75-in. fullrange as in-dash speaker Maytag Snow Car Audio 0 21st February 2011 09:24 AM
F/S Wavecor 7" Nomex Cone ~ Balanced Drive Woofers rubicon Swap Meet 5 5th January 2011 08:28 PM
Anybody have experience of any Wavecor drivers? SOSx Multi-Way 3 23rd July 2010 06:47 PM
Wavecor Listening Impressions rhythmdiy Multi-Way 0 12th October 2008 06:29 PM
anybody experienced wavecor drivers? rhythmdiy Multi-Way 24 18th October 2007 01:25 PM
