Wavecor 6.5" WF160WA02 - Page 2 - diyAudio
Old 13th September 2011, 08:28 AM   #11
jerome69's Avatar
I don't think the marriage between the wavecor and the SEAS will be a success. The sound could be not homogeneous. Just pay attention the tweeter should be well chosen, the choice of the T25 is good. In my setup the marriage with the monacor is not ideal, the distortion of the monacor is low but miss refinement.
The 3 ways is better than the 2.5 A more detailed sound.
Old 13th September 2011, 08:45 AM   #12
alspe is offline alspe  Finland
Usually 0,5 ways driver should be same as mid driver.
BTW, is it always going to be full BSC when used 0,5 way (with same driver as mid)? If yes, it will be too bass heavy for little rooms I think.
Old 13th September 2011, 08:54 AM   #13
re:'0,5 ways driver should be same as mid driver. ' - we'll have to agree to disagree on that, having the same driver just makes it a bit easier.
I'm using an active setup, so can dial in the amount of lower woofer I want
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 13th September 2011, 10:01 AM   #14
jerome69's Avatar
In a 2.5 you can use the woofer you want
With an active setup you can test a lot of configuration
Your 10" peerless could be a good marriage with the ER18RNX in a 3 ways
Old 15th September 2011, 04:16 AM   #15
on closer listening last night, I'm revising my opinion on the midbass... it's not quite present enough. I think the problem is that the box is a bit big & I'm getting a peak at ~ 40Hz which makes the kick drum sound awesome, but higher up (bass guitar fequencies)sounds relatively weak. Further tweaking & measuring this weekend, if the kids'll give me time....
Old 15th September 2011, 08:20 AM   #16
Err,, do you have 1 or 2 Wavecor drivers per side in your 36 l @ 40 Hz tuned reflex box? If you have just one, you'll be getting major bump in response around tuning freq if your T/S measurements are correct (Qts 0,56). That added to natural room gain, 40 Hz plays on top of other bass freq's.
Try 18 l @ 40 Hz box.
Old 16th September 2011, 12:32 AM   #17
Hi Alspe, just one per side.... still breaking them in, so waiting for the parameters to settle down before I decide on final box size/tuning
Old 21st September 2011, 06:58 PM   #18
Have you played them in and are you going to measure parameters again? PLease do it after 200 hr hard playing.
Old 21st September 2011, 11:23 PM   #19
re:'200 hr hard playing' - I'm working on it (prefer music to sine waves :-)...
actually I'm in the middle of building the boxes for my SEAS drivers
Old 30th September 2011, 10:03 PM   #20
some new measurements:
Fs 63.5 (WTF?), Qt .53, Qe .58, Qm 5.32, Vas 12L...
they're very consistent, both drivers being virtually the same, it's dissapointing that Fs has gone UP... but modelling shows them to very forgiving of box size changes, and can get flat down to the low 40s. I got them distorting at one point, it was very gentle 2nd harmonic, no nasty overtones, so they sound good, & can pump the bass beautifully (probably due to a small ~ 1dB, broad lower mid-bass hump in response in most boxes)
Ideal for either a small (~<20L) 2 way, or a pair as the low end for 2.5 or 3 way..
now I really must get on with the boxes for my ER18RNXs... once the neighbours are out of bed.....
Wavecor 2.75-in. fullrange as in-dash speaker Maytag Snow Car Audio 0 21st February 2011 10:24 AM
F/S Wavecor 7" Nomex Cone ~ Balanced Drive Woofers rubicon Swap Meet 5 5th January 2011 09:28 PM
Anybody have experience of any Wavecor drivers? SOSx Multi-Way 3 23rd July 2010 07:47 PM
Wavecor Listening Impressions rhythmdiy Multi-Way 0 12th October 2008 07:29 PM
anybody experienced wavecor drivers? rhythmdiy Multi-Way 24 18th October 2007 02:25 PM
Copyright 1999-2017 diyAudio
