Eminence Deltalite II 2512 Neo 12" Driver
Eminence Deltalight 12......fairly high Q and open frame. Pretty nice LF response vented but don't need below 100hz for this build, only up to 1.5khz. Any thoughts? |
#3 | |
Here's the specs from your link:
Above 100 Hz it may not matter as much, but for bass performance you really would like to see a Qts above 1.00. The woofers on the later version of the Carver Amazing had a Qts of about 2.75 or so, with a Qms of 9 or 10, just to give you an idea of what's optimal for OB. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#4 |
I guess i should have said......qts higher than most pro midwoofers.
Thanx for the response Terry and yes, 120hz on down is covered with sealed subs in stereo. What attracts me to these is as far as pro midwoofers go, the response up to 1.5 doesn't have that gradual rise requiring even further BSC which given an OB alignment would crush the efficiency of most midwoofers. And down low in a sealed box, these won't need a high pass filter at all,as Xmax isn't exceeded until ear bleeding levels so i nice blend to a sub without the interaction of LP/Hp filters. What i'd like to know is how that rearward radiation sounds as these are a REALLY OPEN BACKED designed driver. Might even be TOO OPEN requiring some mechanical attenuation of the rearward radiation. |
#5 |
Hi/lo Q for OB is an old debate.
In almost all woofers we can get, the Qts is dominated by Qes, which cooperates tightly with the output impedance of the amp. Yes, most amps available has a very low output impedance, so this factor is almost always ignored. But it can be changed (with so little effort and cost). Low impedance drive + high Q woofer High impedance drive + low Q woofer Both can give the system Q you want. The choice is yours. |
#6 | |
It's obvious you've put a lot of thought into it already, so it should work out well. Best Regards, Terry
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 17 | 21st May 2012 12:17 PM |
| OB help! | buzzforb | Multi-Way | 24 | 22nd November 2010 06:38 AM |
| S12 OB - Returning to true OB | gainphile | Multi-Way | 39 | 17th April 2010 10:03 AM |
| OB my way | Marmotus | Multi-Way | 32 | 4th September 2008 10:25 PM |
| 3-way OB | Twisted85 | Multi-Way | 23 | 8th January 2008 02:40 AM |
| Page generated in 0.08660 seconds (78.13% PHP - 21.87% MySQL) with 10 queries |
