Old 1st September 2011, 03:33 PM   #1
no gas is offline no gas  United States
Default Tannoy series 1000
I was just given a pair of Tannoy Series 1000's from work when we redid one of our Audio Control Rooms. Any opinions on them? I'm going to use them with my KT-88 SE amp as they are 94Db/W.
My stuff: MC30, MC225, MX110, PAS3, ST-70, RH-84, HK A224 and a lot of parts waiting for time.
Old 2nd September 2011, 05:55 PM   #2
M1000 or System 1000?
Either way Tannoys tend to prefer amps able to deliver lots of current. It doesn't matter that much if the amp is a valve or transistor job.
Even the 215DMTs which are 101dB/1w only really start to sing when driven by a high-current amp.
If they are System 1000 you could eventually run them active with a valve amp for treble and a large transistor amp of any type for bass. a simple 24dB L-R xover at 1.4kHz would do.
Old 6th September 2011, 01:04 PM   #3
They are System 1000s that are bi-amp capable. I've just got them running with my KT-88 SE amps and they sound amoazing! I might go to bi-amp with the KT-88 on the bottom and EL84 SET on the top. We'll see!
Repairing Tannoy "System 1000" HF drivers PhantomBox Planars & Exotics 3 14th March 2011 02:44 PM
Sanken SI-1000 series module datasheets lmaclean Chip Amps 0 1st December 2010 08:58 PM
Threshold S/1000 Series II BrianEno Pass Labs 16 30th April 2009 08:57 PM
Help! Schematic Threshold S/1000 Series II zyhauw Pass Labs 4 11th March 2009 03:47 PM
Tannoy M 1000? Tony.ca Multi-Way 7 7th October 2004 07:55 PM
Page generated in 0.06724 seconds (66.86% PHP - 33.14% MySQL) with 10 queries
