Nelson Pass: The Slot Loaded Open Baffle Project - Page 5 - diyAudio
Old 2nd September 2011, 06:33 AM   #41
Its very simple to sim this kind of "box" in Hornresp.
This is two B&C 15TBX100 in a 50% sd slot and a 1 m2 baffle.
We live in a horizontal world, why use vertical topologies???
Old 2nd September 2011, 06:36 AM   #42
The response-graph above is direct radiation only. The combined response is hard to calculate because of room-interaction and such.
Old 2nd September 2011, 11:59 AM   #43
otto88's Avatar
Rudolf
What do you think of the dispersion pattern: OB - would you build it slot loaded?
Old 2nd September 2011, 12:13 PM   #44
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
don't forget one major advantage of a folded dipole like this
you can have many woofers, without having a huge box
with less woofers you get less SPL
so I would think that a boxed design would need much different woofers
that is if you mate it with a Lowther like Nelson
but kind of OT I would say
Old 2nd September 2011, 02:20 PM   #45
diyAudio Member RIP
Of course one of the first things I did was haul them out into the room
to measure the response difference between front and back. Here is the
(smoothed) comparison measured near field on the woofer system after
the crossover network has been applied. What you see is about about
9 dB pressure difference, equal to my 9 dB thumbnail calculation.
Hmmm .... Oh dear .... in reality practically inconsequential .....
You cannot just use pressure to indicate SPL, you need to normalise it
by multiplying it by the radiating area, otherwise you get nonsense
like small ports being more efficient than large ones, they are not.
Yes, the pressure is higher as the area is less, inevitable measured
nearfield. Farfield there is no difference, there is no efficiency gain
with the arrangement. Volume displacement is the same front and rear.
rgds, sreten.
Old 2nd September 2011, 03:06 PM   #46
oublie is offline oublie  United Kingdom
I sort of concur with sreten on this ive been playing about with hornresp and come up with something that sort of models the design i also ran a baffle simulation and from what ive come up with the 'port' seems to be adding extra path length to the box in essence making a wide baffle but doesnt seem to improve spl.
first two graphs are what i think is a representatio of the slot loaded drivers i may be wrong. The second two are the same drivers on the same baffle without the slot. There is a slight difference in spl down low but this could just be the added baffle size.
I set both to have a path length difference of 120cm
My hornresp design may not be right though.
There are 10 types of people in the world: Those who understand binary, and those who don't...
Old 2nd September 2011, 03:15 PM   #47
ive also modelled a slightly different design. better response but no realy gain in spl.
Old 2nd September 2011, 03:24 PM   #48
The one and only
Nelson Pass's Avatar
You are saying my whole fallacy is wrong, and Heil transformers obviously
don't work as described.
But it's a fact that air moving at a higher velocity carries more energy
and this shows up as greater pressure.
When I said near field, I did not mean that I was sticking the microphone
in the slot - it is true that the farther away you get and as the frequency
goes lower the effect is diminished. I find that the effect is perfectly
adequate for listening purposes.
Old 2nd September 2011, 03:36 PM   #49
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd September 2011, 03:42 PM   #50
It seems like compression would find a way to do Something, especially if the front side has a "hornier" load than the back.
What if you added a deep box for the woofers with a front and rear array. The front array is mounted just like this project, the back array connected to the front array through a deep box opening well away from the OB and floor with no compression ratio. Make the front to back path something like 3 meters and apply a 9mS delay to the rear array drive. This would make about 90 degrees phase shift at 30 Hz and would somewhat reduce the needed box volume? Babble babble.
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 12:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 04:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 05:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 09:11 AM
Which is the nicest open soucre power amp between 40 - 60 Watts from Nelson Pass? Onvinyl Pass Labs 5 21st July 2006 12:55 AM
Copyright ©1999-2017 diyAudio
