Nelson Pass: The Slot Loaded Open Baffle Project
Old 1st September 2011, 09:31 PM   #21
boris81 is offline boris81  United States
Originally Posted by Rudolf View Post
Not really. These polar diagram simulations show (from left to right) a closed box, an open baffle and a Ripole.
Rudolf
I don't think this design functions like a ripole. The idea is that the slot amplifies the front wave only. I expect something similar to cardioid behavior.
Old 1st September 2011, 09:32 PM   #22
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I thought that came out nice. Thanks to Steve for putting it up quickly -
I love instant gratification.
Old 1st September 2011, 09:39 PM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Merged 2 threads on the same topic. If you have only been following one you might want to go back and read the posts you missed.
dave
Old 1st September 2011, 10:11 PM   #24
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
The AMT-3 has a slot ratio of about 3 to 1 in the front. This is rather conservative. Some ripoles have up to 5 to 1 in order to get lowest bass. A ratio of 1.5 or 1 to 1 in the back is common for ripoles too. In simulations (or built ripoles) you hardly see any more change when going below 1.5 to 1. The air space between cone and back slot simply is too large to allow for that. The 9 dB front-to-back difference stated in the article doesn't really qualify as a cardioid pattern IMHO.
Rudolf
www.dipolplus.de
Old 1st September 2011, 10:46 PM   #25
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Did it mention what woofer driver was used? I didn't catch it.
Old 2nd September 2011, 12:48 AM   #26
PeteMcK is offline PeteMcK
slot loading like this would still work even if the rear was a normal BR box???
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 2nd September 2011, 01:19 AM   #27
CLS is offline CLS  Taiwan
That would tend to be a band pass.
Old 2nd September 2011, 01:24 AM   #28
Pano is offline Pano  United States
Pano's Avatar
Does anyone remember a woofer project from about 5 years ago that was slot loaded with 2 woofers facing each other? The guy put it behind his sofa to get strong bass but not disturb the neighbors. I can't find the tread.
Take the Speaker Voltage Test!
Old 2nd September 2011, 01:41 AM   #29
Rudolf
Hypercardioid?
The slot ratio is one thing and then there is the polarity of the drivers. I might be wrong but I was under the impression that a ripole configuration implies both drivers move together in phase. Here they are reversed. I'm not quite sure what effect that will have on the radiation pattern.
A polar graph will be very informative. This is a very interesting design, I'm also curious to see if the sides can be curved without losing much of the 1:3 output ratio.
Old 2nd September 2011, 01:54 AM   #30
winslow is offline winslow  United States
Neighbor friendly dipole sub
I was just looking at it.
Nelson Pass: The Slot Loaded Open Baffle ProjectHide this!Advertise here!
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 12:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 04:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 05:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 09:11 AM
Which is the nicest open soucre power amp between 40 - 60 Watts from Nelson Pass? Onvinyl Pass Labs 5 21st July 2006 12:55 AM
Copyright ©1999-2017 diyAudio
