Nelson Pass: The Slot Loaded Open Baffle Project
Old 5th September 2011, 01:56 AM   #131
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by CLS View Post
This is what I've done during the weekend (when you guys were busy on debating...)
My kind of guy.
Old 5th September 2011, 02:06 AM   #132
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Originally Posted by GRollins View Post
Those of you who know some of the backstory can imagine how that made my day.
And, no, I haven't had a change of heart regarding some of the members here.
Grey
Hi Grey, I'd like to say Welcome back! I hope this won't be your only post.
There are always people who rub us the wrong way, I find it best to just avoid them if possible, and where not possible to allow time to cool down before posting I don't know the back story, but I think you know as well as I do, why certain things said privately need to remain private. There have at times in the past been threads for actively discussing moderation of the site, at the moment that is not the case. Feel free to raise any issues via the report post button though.
I'm sure you know what a balancing act effective moderation is. I hope you can put behind you any history and become an asset to diyAudio once more. I know I'm mentioning moderation in this reply, but if you wish to discuss it further please PM me as this thread is not an appropriate place for that discussion
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 5th September 2011, 02:07 AM   #133
The one and only
Oh no......
http://www.parts-express.com/pe/show...number=246-754
Old 5th September 2011, 02:18 AM   #134
kropf is offline kropf
Originally Posted by Nelson Pass View Post
Actually, my point is fundamentally that the response is asymmetric. I don't
actually care whether it is more efficient on the whole.
If you want to decide that the front loading is causing less excursion of the
diaphragm and thus less output on the rear, that would be OK with me.
The asymmetry is the most important feature, agreed, but improved efficiency wouldn't be bad.
It took me two days to convince myself it was worth entering the fray. After posting, it took about 20 minutes with a saber saw to bring into existence a small, single driver example. The SPL meter and my ears confirm it is a very effective mechanical crossover at about 800 Hz. It sounds just okay, but without the baffle to hide the rear of the driver it is a full range speaker.
Jeremy
Old 5th September 2011, 02:27 AM   #135
eyoung is offline eyoung  United States
eyoung's Avatar
my brain hurts....
slot volume vs driver area* Frequency range and I'm assuming ~1 to 400hz* avg excursion. BTW I like the single sided driver slot as you could use a wall or floor as one side of the slot. I can see dollars flying out the window for drivers as I visualize a slot sub woofer/open baffle mid-low tweet/ with some kind of super tweeter... can you say 6 channel amp with active crossover.
It's also nice to have some color commentary even if the color is grey...
regards, E
"Lead me not into temptation...I can find it myself."
Old 5th September 2011, 02:29 AM   #136
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
When the impedance goes down the efficiency does not go up.
Old 5th September 2011, 03:22 AM   #137
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The oldest guys in that. They had the Aquarius wide dispersion range before L100. Pro sub manifolds, every floor facing sub, even a Karlson, all kinda ''slotty''
Old 5th September 2011, 03:27 AM   #138
The Janis was slot loaded.
Old 5th September 2011, 03:47 AM   #139
flg is offline flg  United States
flg's Avatar
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 5th September 2011, 03:54 AM   #140
Salas's Avatar
Some modern stadium line arrays use it in different guises.
Nelson Pass: The Slot Loaded Open Baffle ProjectHide this!Advertise here!
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 12:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 04:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 05:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 09:11 AM
Which is the nicest open soucre power amp between 40 - 60 Watts from Nelson Pass? Onvinyl Pass Labs 5 21st July 2006 12:55 AM
