Old 28th August 2011, 11:23 AM   #1
Default Magnetic Interference between X-Overs
I am busy assembling a Small Thor speaker set and because of the large Inductors, Madisound had to use two full size circuitboards (one for the tweeter and one for the woofers) to mount the components. Because of space constraints, I now have to mount both boards in line on the rear panel, the only place that I can fit them now.
As the woofer and tweeter Inductor coils will now be close to each other on the same plane, there must be magnetic interference. Any ideas how I can solve this problem please? Turning around the boards will make no difference.
Old 28th August 2011, 11:33 AM   #2
just another
wintermute's Avatar
The usual advice is to mount the coils as right angles to each other. If you can change the orientation of the coils on the actual circuit board that should probably help. check out the following link Placement of coils in crossover networks
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th August 2011, 01:23 PM   #3
pkitt is offline pkitt  United States
If the inductors are air cores and both are laid down flat, as long as there is 2" or more distance between the coils' perimeters (not their centers), there will be no coupling (magnetic, inductive or voltage) having any audible consequence (no matter what Troels implies in his inductor spacing guide).
Paul
Branching x-overs Temporal Multi-Way 4 4th November 2007 10:52 PM
MTM X-overs. Tristanc1 Multi-Way 2 3rd March 2006 03:15 PM
x-overs Madmike2 Multi-Way 3 25th June 2005 11:42 PM
Interference Prune Everything Else 1 22nd September 2003 04:37 PM
Page generated in 0.05680 seconds (83.10% PHP - 16.90% MySQL) with 10 queries
