Hi everyone. I did make a thread on this before, and got one reply. Well that previous thread was about the caps only. So could someone figure out the value of the inductor? It says C681K. I know I don't NEED to replace it, but when I rebuild the crossovers, I get OCD, and want to replace it if possible. The caps are going to be replaced no doubt, but I don't know their values.
FYI the parts are from a Technics SB-2660 Speaker system. I should point out, there is a circuit breaker, and inductor, and two caps per crossover. So because my photos show two, there is only one per speaker. Last edited by ouimetnick; 26th August 2011 at 03:46 AM. |
#2 |
The inductor should be a 0.68 mH 10% tolerance. No clue about the caps.
Ralf |
#3 |
The caps are all 50 VDC. One pair is 3.3 uF and the other 2.2 uF.
Replace with film types > 50 VDC |
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| 3mH inductor, 165uF caps | jazzy | Swap Meet | 0 | 17th February 2011 05:41 PM |
| why use output caps when you can use an inductor? | cuibono | Parts | 4 | 6th February 2008 10:56 PM |
| air core inductor vs. iron core inductor | WBS | Planars & Exotics | 5 | 7th May 2007 11:02 PM |
| Brazil, and some strange laws, not too much strange! | destroyer X | Everything Else | 0 | 11th September 2004 12:38 PM |
| Page generated in 0.06761 seconds (73.71% PHP - 26.29% MySQL) with 11 queries |
