Old 25th August 2011, 10:30 PM   #1
Default sb acoustics mid woofer 5" vs 6"
Hello, I bought 2 months ago two sb acoustics speakers 8" SB23NRXS45-8
The cabinets for them have about 50 liters and even though Vas is 94 liters, the low frequencies are exceptional, I'm very pleased with it.
Now I would like to make a cabinet about 15 liters with one of the folowing speakers:
5" SB15NRXC30-8 - vas 20,7 liters, 50w
SB Acoustics :: 5" SB15NRXC30-8
or
6" SB17NRXC35-8 - vas 44,5 liters, 60w
SB Acoustics :: 6" SB17NRXC35-8
on graphis it's a 3-4 dB difference between them on the amplitude chart
I do not believe that I know enough to make good simulations with popular programs, so I don't know which one would perform better at 35-40 Hz, on a 15 liter cabinet.
The price is almost equal, 56 euro for the 5", and 62 euro for 6".
5" or 6"?
Thanks.
Old 25th August 2011, 11:16 PM   #2
there's no substitute for Sd when you need to move LF air, but you need the right sized cabinet to boot (Hoffman strikes again...). The 5" is probably a better match for that size cabinet, but you'll have to compromise on the LF extension...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 26th August 2011, 01:00 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
I have used the 5", it measures exactly as per the spec sheet on an IEC baffle and I was able to make it VERY flat on an actual baffle. I haven't used the 6", but I have heard it, also quite a nice driver.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 26th August 2011, 10:33 AM   #4
Is the 5" driver enough for a small room party let's say 40 square meters?
When I bought the 8" I did not realised how powerfull it is, and how big is a 50 liter (inside) cabinet, almost 70 liters (exteriour). The sound is verry good, but I do not listen to more than 2-5 watts except at parties.
This is why I would like something small, but with good sound.
The cabinet for the 6" is also big, I think minimum 25 liter inside, this could be 32-33 the exteriour, I it was ok for a column, But I want something to put on my desk, not near it.
Old 26th August 2011, 11:13 AM   #5
Ron E's Avatar
I would never recommend a 5" for a party speaker. These will take some abuse, though.
Old 26th August 2011, 12:44 PM   #6
jerome69's Avatar
I have already seen a 5" use as a party speaker
It was a carbon 5" in a RCF speaker. RCF is known for PA speakers.
The problem with small driver is the amplifier must be enough powerful to handle correctly the driver.
With the SB 5" you can achieve near 100dB SPL enough for a party. The problem could be bass output but if you limit it, no problem.
NB: For 15L the 6" is Ok. The kit use a 15L box http://www.sbacoustics.com/index.php/products/kits/eka/
Old 26th August 2011, 12:52 PM   #7
lduarte1973's Avatar
What material is the cone of the SB23NRXS45-8 made of ?
Old 26th August 2011, 12:59 PM   #8
I don't know what is the material, in the specks it war written coated.
SB Acoustics :: 8'' SB23NRXS45-8
Old 26th August 2011, 01:01 PM   #9
This is what I was wondering.
In the same box 15-16L, which one would produce a better low frequencies?
Old 26th August 2011, 01:03 PM   #10
Maybe because de box is small, the +3,4db that the 6" has more on the charts, would be lost, or even more 5-6? at 45 Hz for example?
SB Acoustics 10" woofers Jimmy154 Swap Meet 15 4th May 2011 09:23 AM
FS: 2 - SB Acoustics 10" SB29NRX75-6 Jimmy154 Swap Meet 3 10th July 2009 08:30 PM
SB Acoustics 6" Params TurboFC3S Multi-Way 15 20th February 2009 01:43 PM
3-way + sub woofer near field "mid" to HI-FI PC speaker system firefart_1st Multi-Way 2 9th September 2008 11:07 PM
FS: Snell 6.5" - 7" mid-bass driver woofer feke67 Swap Meet 0 31st December 2007 07:11 PM
Page generated in 0.10011 seconds (82.73% PHP - 17.27% MySQL) with 10 queries
