#1501 | |
To me it is an iron law: If you leave the vicinity (nearfield) of the sound source and let the room do (too much of) its work, you loose the detail and the resolution, but you gain envelopment and the sources become bigger. Of course it was only recently that I became aware in some detail how these things work in conjunction with acoustics and the human brain. Rudolf
www.dipolplus.de |
#1502 | |
Sharp imaging, I think, is the key issue is this whole directivity discussion. Sharp imaging is required in the production end, as most recordings are done with a microphone placed close to the instrument and positioned in the acoustic space afterwards. It is not the 'original event', but a production. As we know from this discussion: magnitude, time-delay, direction and number of reflections have influence on imaging and envelopment, exact numbers are unknown. I would say that at the reproduction end the loudspeakers must be able to deliver the same sharpness in imaging as the production end, just like a 1080P HD movie doesn't come to it's full potential on a 20 inch SD television. Omni's, dipoles and conventional boxes are all perfectly capable of delivering this sharp image, but in general they need more distance to the walls to deliver the same sharpness as the narrow directivity waveguide speakers can deliver. So, room size dictates the directivity pattern. Remains spaciousness and ASW. Both should, in my opinion, be controlled at the prodcution side. It can be done, a nice example is this one:
El Cuerno: Cardioid waveguide, four subwoofers and BruteFIR/Linux DSP |
#1503 | |
Markus |
#1504 | |
Unless the loudspeakers are close to the side walls, I've not heard center become "ambiguous", or even altered much in any fashion (..again, assuming equidistant speakers that are equidistant to their ipsilateral wall.) So, for me and those I've tested - it isn't happening. Now alter the direction of the loudspeaker (i.e. "toe-out"), and yes - center *can* start to become more ambiguous. Is this a function of the ipsilateral wall, or that of the driver + baffle? Considering I've used heavy insulation to test this on the wall I can say without a doubt that it's the loudspeaker, NOT the wall. Assuming a member has access to loudspeakers, it's not difficult to test any of this. Of course none of this is to say that the wall doesn't contribute as well in these circumstances, rather that the manner of it's contribution is an alteration that doesn't really impact it's clarity with respect to position. Now the *contralateral* wall, that can often "stretch" and image somewhat - in a similar manner to "apparent source width" for acoustics. Of course it also has other negative qualities with respect to cross-talk, tending to "shrink" sound-stage width to the boundaries of the loudspeakers depending on the horizontal polar pattern of the loudspeaker.
perspective is everything |
#1505 | |
I'm not sure about "envelopment" however - I suppose it would depend on your definition.
#1506 | |
#1507 | |
#1508 | |
I don't think that we can fully understand how this is happening without answering the fundamental question "why do we hear a center phantom image in stereo". |
#1509 |
Well, that one is fairly simple. This was nicely described in some papers by Ben Bauer that were published in JASA in the early 1960's. The topic was called the "theory of stereophony".
#1510 | |
Markus |
| Wide polar pattern speakers via Diffusors | noodle_snacks | Multi-Way | 6 | 11th May 2012 07:47 PM |
| Driver pattern, directivity and other confusing issues | mefistofelez | Multi-Way | 2 | 19th January 2006 03:56 AM |
| What speakers would be ideal for my room | AJ Bertelson | Multi-Way | 2 | 27th April 2004 09:31 PM |
| Ideal HT Speakers (Worried about Subwoofer Crossover) | Ignite | Subwoofers | 2 | 19th October 2001 04:18 AM |
| Page generated in 0.57258 seconds (100.00% PHP - 0% MySQL) with 10 queries |
