#1011 | ||
![]() Interesting, that's definitely a bit more live than what I have at the moment, but then your room is quite a bit bigger and more sparsely occupied. Quote:
The rug will help a lot above about 1-2Khz, but there is going to be a lot of side-wall bounce in the low midrange that will do weird things to the stereo balance, if my own experiences are anything to go by. I find that if both speakers are at least 1.5 metres from the side wall it doesn't matter if they're unequal distances, but once they're down to 1 metre or less unless both speakers are identical distances from their respective side-walls (within a few centimetres) the image is never perfectly balanced, and even then there is always tonal imbalance in the low midrange. (Just an equal tonal imbalance in left and right) Not sure that I have any suggestions though, given your layout...
- Simon Last edited by DBMandrake; 18th September 2011 at 10:45 PM. |
#1012 | ||
- Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#1014 | |
The number is higher than you would normally find in any scientific peer revieved paper !
![]() Quote:
![]() - Elias
#1015 | |
#1016 | |
Those numbers are quite different from e.g. here: See post # 470 ![]() - Elias
#1017 | |||||
(of course not a real sursprise since I explained it already carefully, it was FE126En)Quote:
- Elias
#1018 | |
I cheaked and Blauert's data is no where near as extreme as Dave was quoting (figure 3.5). His MAXIMUM level offset for a central image is about 9 dB, and that's for a 4 ms time difference. This is certainly different than what Dave was quoting. |
#1019 | |
Statistically, I see that many domestic installations have the speakers close to the boundaries, show big asymmetry, are stuffed by some furniture (ahh, a piano...), AND have some acoustic treatment, mostly absorbing for HF only. Mine is just the opposite (rigorous symmetry__see boris, post 1179__, empty space, speakers only close to the floor, membrane like boundaries reflecting mainly HF, all this for the sake of side firing). I think that here are the roots of the difference. But after all, it's not a problem, each of us is happy with the best adaptated configuration. Last edited by Radugazon; 19th September 2011 at 01:16 AM. |
#1020 |
Radugazon, I think your explanation is more probable than Elias's. Hopefully he does too and was just trolling. Not very good odds that everyone you brought in all had superior hearing. He's always argued that he's a 'superior hearing, high powered pinna' anomaly. Not many people wanting to build a speaker or playback system for the one in a million. Not good business.
Dan |
| Wide polar pattern speakers via Diffusors | noodle_snacks | Multi-Way | 6 | 11th May 2012 07:47 PM |
| Driver pattern, directivity and other confusing issues | mefistofelez | Multi-Way | 2 | 19th January 2006 03:56 AM |
| What speakers would be ideal for my room | AJ Bertelson | Multi-Way | 2 | 27th April 2004 09:31 PM |
| Ideal HT Speakers (Worried about Subwoofer Crossover) | Ignite | Subwoofers | 2 | 19th October 2001 04:18 AM |
