What is the ideal directivity pattern for stereo speakers?
Old 5th November 2011, 05:12 PM   #1891
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by speaker dave View Post
Finally.
The answer we've all been waiting for.
We can all go home.
You beat me to it. I read that comment and thought the same thing.
Earl Geddes Gedlee Website
Old 5th November 2011, 05:59 PM   #1892
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by KSTR View Post
Exactly. I've extensively played with static 2-->3 rematrixing, simplest form is : C=L+R, L'=L-0.5R, R'=R-0.5L, and +45, 0, 45 deg angles, known as Trinaural.
- Klaus
Klaus !
Are you sure about the equation ? For C I think C = 0.5L + 0.5R ?
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 8th November 2011, 01:00 PM   #1893
KSTR is offline KSTR  Germany
KSTR's Avatar
Elias, you're right, thanks for correcting that.
The more generic equation, as given by Michael Miles from MilesTech and coined "Optimum Linear Matrix", is :
L' = L - kR
R' = R - kL
C = (1-k)(L+R)
With k = 0.5 it's "Trinaual
- Klaus
Old 9th November 2011, 11:13 AM   #1894
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I made myself a new speaker testing stand today with swivel at the top to allow me to easily do off axis measurements. I've attached the results of 0 through 90 degrees off axis for my MTM, same ones that were used for the pink noise tests above, just to give some context I guess
First pic is all the measurements in 15 deg increments through 90 degrees. Note that there were a bunch of plants that the speaker would have been pointing directly at between 30 and about 75 deg, whether or not these affected the measurements I can't say because I was too lazy to move them
I did fairly low spl level measurements as it was after 9:00pm
the second pic is the holm measurements for zero 15 and 30 showing the impulse response as well.
Tony.
File Type: png new_crossover_1.27M_with_15_and_30_off_axis.png (73.6 KB, 171 views)
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th November 2011, 12:27 PM   #1895
keyser is offline keyser  Netherlands
keyser's Avatar
It look like the distance between speaker and mic is a bit larger at larger angles. Did you turn the speaker around it's baffle centre-axis, or at some axis more to the rear of the speaker?
Dutch & Dutch
Old 9th November 2011, 01:36 PM   #1896
keyser's Avatar
Damn, more than one typo in a two-sentence post. Too bad I can't fix it anymore.
Dutch & Dutch
Old 9th November 2011, 03:24 PM   #1897
auplater is offline auplater  United States
auplater's Avatar
Default RD75 dipoles
Here's my 6' dipoles at 0, 15,30,45, & 60 (green,red,purple,blue,brown) offset in ARTA for ease of reading. I'll have to set up to do the in/out of phase measurements
smoothed 1/24 octave back in 2008
And here's an on-axis attempt to maximally flat (which sounded way too brite, btw, hence the subsequent designed-in tilt) Click the image to open in full size.
All measurements taken @ ~ 15 feet from speaker @ 3' height
John L.
"I've forgotten more than I care to remember" The Last Conspirators
Old 9th November 2011, 08:07 PM   #1898
just another
wintermute's Avatar
Yes the pivot point is not quite on the front baffle axis, it is about 1" behind it, which does introduce a little error. I could move the speaker back a little further but then I start to get diffraction effetcs off the platform.
edit: I guess you picked that up from the impulse response? I time zero locked it so that time of flight was absolute between the measurements
Tony.
Some of my photos
Last edited by wintermute; 9th November 2011 at 08:10 PM. Reason: add impulse response comment.
Old 9th November 2011, 11:42 PM   #1899
gedlee's Avatar
1" of offset is not going to make any difference. I often have 3" or so and I don't see any effects from this. I also worried about diffraction from the platform, but I haven't found that to be much of a problem either.
Old 10th November 2011, 01:58 PM   #1900
Pano is offline Pano  United States
Pano's Avatar
See Tony's pivoting measurement stand here:
http://www.diyaudio.com/forums/equip...ing-stand.html
What is the ideal directivity pattern for stereo speakers?Hide this!Advertise here!
Wide polar pattern speakers via Diffusors noodle_snacks Multi-Way 6 11th May 2012 07:47 PM
Driver pattern, directivity and other confusing issues mefistofelez Multi-Way 2 19th January 2006 03:56 AM
What speakers would be ideal for my room AJ Bertelson Multi-Way 2 27th April 2004 09:31 PM
Ideal HT Speakers (Worried about Subwoofer Crossover) Ignite Subwoofers 2 19th October 2001 04:18 AM
