I see very little usage of the "New Vifa" tweeters on any diy forums. In particular, ones like this:
Vifa NE19VTA, 3/4" Aluminum Dome Tweeter, 4 ohm: Madisound Speaker Store It seems to have very low sensitivity for a 4 ohm version, but the response is quite flat, even far off axis. It also seems to be able to cross over very low. Has anyone used these? Or any of this basic design (including the soft dome version)? Pros, cons and impressions would be appreciated. Links to builds would also be great!! Thanks in advance. |
#2 |
I use it for a desktop monitor and it is cool. The bigger models have high sensitivity so can be used on my open baffles. This drivers are pretty new so there is some time span until amateurs and professional catch up. I think you will see them more often soon.
#3 |
#4 |
I have been looking at the soft dome version of this at PE, I think I will try them next.
#5 |
I've been thinking about using these in both home and car. For the car they look almost ideal with very good off axis response. It also looks like I can easily cross them as low as 2000 hz. For home it may be used in a center channel. Silver Flute 6.5 inch for both. My only caveat is the sensitivity mismatch. They are not far off 89 vs 91 db. I know it's common practice to used an L-pad on a tweeter, but how about the woofer if need be?
#6 |
The Vifa NE19VTA fit perfectly in my application because of the extended response and small size. I have no problems to report with this tweeter even though I use it for over a decade (LR4@1.4kHz).
Build Thread: Ardor - point source monitor This is an extremely linear driver, I get a +-1dB curve with just minor adjustments. Zaph measured the entire product line on his blog and found higher than usual 2nd harmonic distortion. I personally find nothing wrong with the sound of this tweeter. I can try running some tests with it if you have something in mind. |
| WTB: Two Vifa D27TG-05-06 tweeters and two Peerless 832873 HDS 5-1/4" Woofers :) | Big_Bill | Swap Meet | 7 | 13th October 2010 03:12 AM |
| FS: Peerless SLS 830667 8", PPB 830870 4", Madisound OEM 8" Woofers, LPG Tweeters | omarmipi | Swap Meet | 1 | 1st September 2010 06:53 PM |
| ACI 12" sub drivers (2), Vifa 8" poly (4), North Creek D26 tweeters (2) | nodiak | Swap Meet | 2 | 29th October 2007 03:45 AM |
| FA/FS: Vifa Built 1" Silk Dome Tweeters | CanuckAP | Swap Meet | 0 | 23rd November 2002 05:19 AM |
| Page generated in 2.98924 seconds (2.95% PHP - 97.05% MySQL) with 10 queries |
