I'm trying to make a 4 way speaker with acoustic crossover.
Well, it's probably going to be partially acoustic. Ideally there would be just three capacitors and some foam. I like how enclosure shapes came out, design is accidental. I just rearranged parts of this waveguide TwisterSpeakers: Neo8 planar transducer in a waveguide DSC_3078.jpg DSC_3085.jpg DSC_3081.jpg IMG_0052.jpg IMG_0053.jpg IMG_0056.jpg |
#2 |
So... the red baffle does it all ?!? Rifraction ,diffraction , small chamber ,lowpass ...
#3 |
yes, it's a special kind of baffle. red paint helps to reduce bad stray waves. and its shape completely eliminates diffraction.
it's not the final design, you'll see some other objects attached in front of transducers.
#4 |
super aerogel pillows ?
#5 |
sarcastic mode on : this could become a nice couple of Christmas trees, branches helping to control the polar.
sarcastic mode off : why not ? Finally something original, and all the horns and loads are also acoustical devices |
#6 |
fantastic design, (monkey coffins are sooo boring)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency |
#7 |
pretty looking drivers too
![]() Good luck with it!
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#8 |
Thanks ) Top three drivers are behaving according to the plan. Only caps and foam work fine, they just need to be better balanced.
The lower woofer(yellow line,unfiltered) is problematic, I need huge amount of foam to make acoustic low pass. I'll try to compress foam(make it denser)or look for another sound absorbing material. firsst-test.gif |
#9 |
Lower driver requires huge amount of foam or pillows to be low passed around 300hz. Probably closed cell foam could work, but unfortunately I don't have one.
I'm going to build bandpass enclosure for this driver (add another box with port) Can anyone recommend a good free bandpass calculating software? Overall this acoustic filter concept works very well, I've been using it in my car audio for several month. I think that a simple block of foam can greatly improve sound of any cheap speaker, when placed in front of the drivers. |
| Boston Acoustic A200 crossover | 503Timber | Multi-Way | 0 | 6th July 2011 11:57 AM |
| Acoustic plus electric rolloff crossover question | Tyson | Multi-Way | 2 | 25th January 2010 12:54 AM |
| repair'-Acoustic 450 distorted and low volume. Transistor crossover distortion? | Willampsburn | Solid State | 1 | 14th March 2008 02:39 PM |
| Acoustic Crossover | kspv | Multi-Way | 3 | 8th July 2004 02:07 PM |
| Definition of 4th order acoustic crossover | moving_electron | Multi-Way | 4 | 8th April 2004 12:21 PM |
