Old 19th August 2011, 05:10 PM   #1
Default Tweeters for 1st order crossover
Hi all!
I would like to replace my current tweeter (older Vifa D27TG) with another tweeter. The concept of the speaker calls for a tweeter that works well with just a single cap in series and a fairly high crossover frequency of around 3,5 to 4,5kHz (that would approximately lead to a single 3,3uF cap for a 8 Ohm tweeter and a 4,7uF cap for a 6 Ohm tweeter).
It has to be a tweeter with a 104mm faceplate, a quite flat frequency response and a flat impedance curve. Oh, and a not so high sensitivity would be great to omit any resistors in series. Something around 88-90dB would be nice.
I searched the net and I'm particularly interested in these tweeters:
Seas 27TDFC
Morel CAT-308
Peerless/ScanSpeak 810921 (D2608/913000)
Vifa HT 270 VF/6 (same as ScanSpeak D2606/922000)
Although I read that the Peerless 810921 isn't that happy with just a cap and needs a few more parts to get it to sound right.
Regarding the other three I just can't decide which one to buy!
(Budget is tight so it's not a great idea to buy all of them.)
Any experiences with 1st orders on these tweeters would be appreciated!
Martin
Old 19th August 2011, 05:20 PM   #2
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I ran XT25's like that for a long time, but in the end I ended up with something a little more complex.
Old 19th August 2011, 05:47 PM   #3
That's exactly the problem. I already tried the XT25's, like their sound but they have a impedance rise at the resonance frequency that has to be flattened with a parallel notch and they just won't respond to a single cap! They simply have too much energy at lower frequencies. One has to use at least 2nd order to get them to work properly...
Old 19th August 2011, 06:05 PM   #4
infinia is offline infinia  United States
infinia's Avatar
I've used the Morels with a single series 8uF cap w/o problems at > 100 W. Recommended for 1st order designs b/c Dynaudio technology.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 19th August 2011, 06:43 PM   #5
Zero D is offline Zero D  United Kingdom
Morels are nice I havn't heard that one though.
I do prefer 1st order, with the right drivers
Old 19th August 2011, 08:19 PM   #6
A single 8uF cap you say? Well, in this case I think I won't get any problems with a 3,3uF cap at all!
I heard about the high power handling capabilities of the Morel drivers, but how do they sound with a 1st order x-over pushed hard? Do they stay smooth, effortless and well controlled?
(I know, I'm asking pretty much here...)
Btw, it seems the CAT-308 is a replacement for the MDT30 (or MDT30S). Which one did you try?
Old 19th August 2011, 09:10 PM   #7
DrDyna's Avatar
Eek, up to 100w with an 8uF cap! Those must be some beefcake tweeters. I'd expect welded voice coils if I pulled that trick. I'd guess that with a 4.7 or 3.3 they should be able to give you any volume you'd ask for, unless you're trying to fill an auditorium / chapel.
Old 19th August 2011, 09:36 PM   #8
infinia's Avatar
Martin, I bought a case lot of the MDT-28S pretty much the same replaceable dome/VC assembly as the 30's. on that I expect CAT-308 to be just as good if not better. I crossed very low to mate with a 8" woofer. IMO sounds/acts very similar to Dynaudio D-28 AF, which I also use, if you've ever heard those. They sound smooth and clean pushed hard but I'm not a fussy guy.
Old 19th August 2011, 09:42 PM   #9
infinia's Avatar
Actually used a 200W amp with a 8 ohm 3 dB pad. have not burn't any out yet. While watching the amp clipping lights, I detected some thermal compression up there. I wouldn't recommend long term with highly compressed music, MP3s and such ie not pro-sound
Old 20th August 2011, 03:36 AM   #10
I want to mate them with a 8" woofer, too, but one with a very extended frequency range up to 4kHz with a single 0,82 or 0,68mH coil in series. Another reason is, I just like the sound of a midrange covered by a large woofer. But no pro audio here, just for the living room. And yes, I know the Dynaudio D28 AF. Unfortunately these are no longer available for the diy'er.
1st or second order crossover for sloped baffle fin1bxn Multi-Way 5 15th September 2008 07:17 PM
1st order crossover design! davidbosch Multi-Way 3 27th March 2008 10:02 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
1st and 2nd Order Crossover Design rookster Multi-Way 16 11th May 2003 05:36 PM
Crossover - 1st Order GeniX Multi-Way 3 20th September 2002 02:39 PM
Page generated in 0.11113 seconds (83.88% PHP - 16.12% MySQL) with 10 queries
