I have seen a few speakers intentionally designed with the tweeter placed below the mid/woofer. A while back I took small speakers I used to use for near field, and placed tweeters on the bottom. Originally I wanted to get the port breeze out of my face. Then I noticed what seemed to be a more cohesive sounding reproduction. The speaker was designed to have the tweeter on top.
Why is that?
"It is much easier to be critical than correct." -- Benjamin Disraeli |
#2 |
have a look at this series of directionality plots from John's site, and imagine them flippped upside down:
Power
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 | ||
From the book: Quote:
Now after all I read? I found nothing to explain what might be gained with having the tweeter located below the woofer. That was my question.
#4 |
I have done it, it works or it did for me, but I did it as a cost effective way of building, as it was easy to get the tweeter at ear level in a 1220 sheet of MDF. XO was electrical LR 2 and I must have got the acoustic response to match that as it wasn't at all bad.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#5 |
Usually inverted driver arrangement is used with using odd order filters to compensate for the downward polar tilt caused by phase differences between the HP and LP. Reverse the drivers and if they are placed to give the right upward tilt can give a 0° ZDP (zero delay plane).
There's a good section on this in the Loudspeaker Design Cookbook (6th ed, section 7.23). |
#7 | |
#8 |
You may still be closer to a reflecting surface that way, or depending on your ear height relative to the tweeter could have changed if you're in near field also.
#9 |
Flipping a pair of loudspeakers around will completely change the phase relationship between the two drive units and your ear and depending on the design could result in a significant change between the frequency response of each arrangement. It is not surprising that they sound different. As to which way is best will only really depend on one thing - which way you think sounds best.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#10 |
GeneZ, have another look at those graphs. What they are showing you is how the sound radiates into the room, looking at the speaker from the side. If flipping the speaker makes a difference, you have odd-order crossovers, and the directionality change, combined with your listening position, works better for you.
| A few doubts about side woofer line array. | goldyrathore | Planars & Exotics | 1 | 18th September 2009 05:58 PM |
| Morel 8in Woofer (MW265) and Top Mount Tweeter (MDT41) | mmgando | Swap Meet | 2 | 13th December 2007 04:16 PM |
| Side Firing Woofer Concerns? | Gcollier | Multi-Way | 1 | 1st September 2005 02:12 PM |
| side fired woofer | Cheap Shot | Multi-Way | 4 | 12th May 2005 06:50 PM |
| OP Amps pinout, ok. But wich side is the top? | Bricolo | Parts | 16 | 12th February 2003 09:05 PM |
| Page generated in 0.10275 seconds (81.85% PHP - 18.15% MySQL) with 11 queries |
