#21 |
The baffle wall will of course be flush with the front of the cabinets, yes.
Did a few measurements and eq today, and already much better. The harshness was a peak in the 500-1100 area. Brought that in line and put the crossover to 1,2kHz and the transition is much smoother. |
#22 | |
Beyma is a constructor of pro drivers... Directivity is not the first concern. Imagine the distance is long and even if the angle of radiation is narrow, it is enough to cover the surface you want. I don't try to say i am right or not, i am agree with what you write, it is an other point view. Directivity could be a good thing in some case when you want to concentrate the wave on one place (the dance floor for example |
#23 | |
#24 | |
#25 |
I believe TPL150H is constructed by Beyma for mating with 12" around 1200 Hz dispersion-wise, ref. their own design at www.beyma.com.
#26 | |
The example you cited is just that, an example of one of many possible configurations the designer has at his fingertips. |
#27 |
I totaly agree; the TPL150H is CD in the horisontal plane from around 1200 Hz and far up in frequence. It's just a matter of mating with midband speaker at a frequence where both have similar dispersion, e.g. an 8" might be XO'ed with the TPL150H around 1700-2000 Hz?
#28 | |
Feedback can be a bastard to fix so you need to take extra care of the all the speakers and microphones directivities. |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Active crossover | ivan-UTN-ARG | Tubes / Valves | 3 | 3rd December 2007 12:39 AM |
| active crossover | barossi | Multi-Way | 7 | 14th August 2006 08:37 AM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
