Old 17th August 2011, 08:03 PM   #1
mondogenerator's Avatar
Default I nearly threw out this box when I had an idea...
I have an MDF test box I was thinking about throwing away, since they were doing nothing.
yes its MDF and maybe imperfect, but its about 15 litres and solid at 1½" thick....enough room to shape the corners some....
Anyway then I got perhaps an obvious idea. cut it in half anf make 2 ~7litre boxes..?
Et Voila!
A little rough cut, but i plan to shape the edges as they are now, for a baffle edge of as useful a radius as i can.
My first thought for the drivers was the pair of idle Audax Ap100ZO, and TM25F1 a la the Hennessy, except in a vented box, or I may use a pair of the TB W2-800SL I have here, and cross much lower. for the Audax at 7 litres, the box is slightly too small, WINisd gives 9l for a max flat alignment, tuning lower and dropping the volume down to 7litres gives me a fairly good result, simming in WINisd at least.
Has anyone got any other midwoofer that would be worth considering in place of the Audax?
-10dB cursor is at ~36-38Hz which i found quite surprising for the 4" driver.
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone.
Active Box Idea Dxvideo Chip Amps 15 27th August 2008 12:15 PM
New idea for FR125S box Rafal Full Range 13 10th March 2006 06:00 AM
Dual aperiodic box idea Dave Jones Multi-Way 12 21st April 2005 03:48 PM
Page generated in 0.07416 seconds (70.49% PHP - 29.51% MySQL) with 10 queries
