T/S + Maths = Help!!!
Old 27th August 2003, 02:34 PM   #1
Higo is offline Higo  Argentina
Question T/S + Maths = Help!!!
Hi boys:
Im building a 2-W speakers (surround) in a sealed box with these T/S:
Revc= 5.6 ohms
Fo= 53.0815 Hz
Zo= 29.8878 ohms
Sd= 0.0132 m2
BL= 7.7514 TM
no= 0.5374 %
SPL= 89.3211 dB
Qms= 1.8709
Qes= 0.4314
Qts= 0.3506
Vas= 16.0287 lts
Cms= 647.8159 uM/N
Mms= 13.8772 grs
Mmd= 13.0052 grs
I build a sealed box of 8.2 lt. This means a QTC 0.6 and Fb 90 Hz
Am I right with the maths?
The mains (sealed box too) have these T/S:
Revc= 6.3 ohms
Fo= 46.2552 Hz
Zo= 30.9856 ohms
Sd= 0.0216 m2
BL= 8.8430 TM
no= 0.5570 %
SPLo= 89.4767 dB
Qms= 2.2011
Qes= 0.5617
Qts= 0.4475
Vas= 32.6946 lts
Cms= 493.4815 uM/N
Mms= 23.9910 grs
Mmd= 22.1657 grs
I build a sealed box of 42 lt. This means a QTC 0.59 and Fb 61 Hz?
Again: Am I right with the maths?
Any help will be appreciated.
Thanks for your time.
Marcelo
There is no emotion; there is peace.There is no ignorance; there is knowledge.There is no passion; there is serenity.There is no death; there is the Force.
Old 27th August 2003, 03:47 PM   #2
LaMa is offline LaMa
To verify this I think you can use a computersimulation which takes account of changes of Le. Try Unibox it's free (but you have to have MS Excel)
Old 28th August 2003, 12:21 AM   #3
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
The basic formula has been known for a long time-the fifties at least.
As you know, when a speaker is placed in a box less than 3 times as large as it's Vas, there is a rise in resonance and in Q.
Fs = free air resonance "free air" means outside the box.
Qts = total free air Q
Fc = resonance in closed box
Qtc = Q in closed box
Vb = volume of box
a = (VasVb)
So:
Fc = (a + 1) X Fs
Qtc = (a + 1) X Qts
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 28th August 2003, 12:44 AM   #4
Wizard of Kelts
So for the satellites, the folowing important numbers are given:
Fs= 53.0815 Hz
Qts= 0.3506
Vas= 16.0287 lts
For an 8 liter box, we have:
Qts = [(16/8.2) + 1] X 0.35 = 0.6
Fs = [(16/8.2) + 1] X 53 = 91 Hz.
You are right with the satellites.
For the main speakers of 42 liters:
Fs= 46.2552 Hz
Qts= 0.4475
Vas= 32.6946 lts
Qts = [(33/42) + 1] X 0.45 = 0.6
Fs = [(33/42) + 1] X 46 = 61.
You are correct with the main speakers as well. Any inductors you place in series with the speakers will raise the Qtc somewhat.
-Anonymous
T/S + Maths = Help!!!Hide this!Advertise here!
Maths ....??? Bluto Multi-Way 31 4th March 2008 06:28 PM
maths Notagenius The Lounge 0 12th October 2007 08:42 AM
Maths Course mikee55 Multi-Way 8 10th October 2006 09:19 AM
Maths help :( shudster Multi-Way 7 28th January 2006 08:36 PM
