Would 2in. Or 2.65in in diameter be appropriate for a 15L enclosure?
For 43hz tuning, the 2in. Port would be around 19cm in length and 2.65in would be 23cm. Does it sound right? |
#2 |
The size of the box doesn't matter, except that it's a matter of being able to fit the desired port inside the box. The purists will howl, but I use ~ 2" for most ports, unless you're listening at extreme volume levels, port turbulence won't be an issue.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
Hi, 2" is around 18/19cm but 2.65" is way more than 23cm, near 33cm, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 |
I just finished a project with a 15L box, 2 inch diam port tuned to about 42 hz. Port length worked out to be about 23 cm. (i.e. 9").
#5 |
I've read from somewhere that the actual port length will be about .7 of what you calculated from the equation.
So .7 (33) = about 23 is what I got for 2.65in. dia. |
#6 | |
The port diameter is a balance between vent velocity and pipe organ effects. The overall port length is another factor. You want the vent velocity low enough to prevent port chuffing. However, port pipe organ resonance is also a function of port diameter and length. The effect will create a bump in the frequency response somewhere up the line. The larger the port area, the larger that bump can be. If you are building a sub, having a very large port area is not so much a problem because the port pipe's resonance point will typically be above the sub's cutoff frequency. |
#7 | |
#8 | |
Vance Dickason's Loudspeaker Design Cookbook has good information about this effect and other effects with ports. |
| What happens to port dia/length when an enclosure is doubled? | gripracer | Multi-Way | 3 | 27th October 2009 11:32 AM |
| Port outside the box?? | quickshift | Subwoofers | 3 | 24th November 2005 01:37 PM |
| need a sub box port | Jobe | Parts | 3 | 26th February 2004 07:19 AM |
| how to vent the port dia? | Tony.ca | Car Audio | 6 | 4th June 2003 01:10 AM |
| port and PR in the same box? | Rory | Multi-Way | 15 | 6th September 2001 02:09 AM |
| Page generated in 0.09495 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
