Happy Chappy
Is there a good formula for speaker size in relation to the room’s size?
I want to build some speakers that fit the room my hi-fi is in. At the moment I have a choice of speakers : RTL TDL2’s mk1’s B&W 602’s These are hooked upto a AC Azur 650 A AC Azur DacMAgi Sony SACD. I find the B&W’s are to powerful, hard to explain the room somehow makes them sound muddy at medium volume, but this get less as I lower the volume, it’s as if the sound bouncing back at the speakers , I can’t explain it I’m no audiophile, I just like what I hear. The rooms about 20 ft by 16 ft, and I listen between the 16ft walls. So sat in my chair I’m probably 12 feet from the speakers. Anyone recommend a speaker size for those dimensions I could easily build? I’d like just a all-round listening speaker, I don’t mind spending money on good parts and the case I can make at my friends joinery shop. |
#2 |
Happy Chappy
Sorry I forgot to mention the TDL's , I had a Pair 20 years ago and loved them, I bought this pair , because I wanted to see if I could create another set with better parts.. they are tired, old and scratched .. bit like me , but somebody has to love them.. I will be taking them apart soon
#3 |
Move the B&W's away from the back wall and side wall, until they sound right. Its not rocket science, and done properly bass extension will sound better. They must be on correct height stands, to work well. Moving your chair away from the back wall will smooth bass. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 | |
Happy Chappy
Smaller speaker with higher specs I think may help the room accustics? After reading other threads its seems the amp you are hooking up to makes a difference in speaker part choice. The AC 650a :- Power Output: 75 Watts (into 8 Ohms) THD (unweighted): <0.002% @ 1kHz, 80% of rated power <0.03% 20Hz - 20kHz, 80% of rated power <0.02% 20Hz - 20kHz @ 10W Frequency Response: 5Hz - 50kHz (-1dB) Signal to Noise Ratio (No weighting): >92dB Input Impedance: 47kohms Power amp damping factor: >100 Max. Power Consumption: 600W |
#5 |
I basically completely disagree. Your room is big for the speakers. Try lining the ports with 1/4" open cell foam, length x 3xdiameter to tighten up bass, And typically make rear wall distance ~ half stand height and typically side wall distance ~ double, or more. rgds, sreten. Your other options are to go with a large rear wall distance, greater than effective stand height. This gives the best lower bass boost.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 16th August 2011 at 02:47 PM. |
#6 | |
Happy Chappy
#7 |
There is a lot to be said for putting them (and yourself) in the right location. Upper bass and midrange will benefit from this. Bass is different, subs can help, but I'm speaking here in the interest of placement not bass extension. Small changes can be worth trying. Subtle, but not...
#8 |
Happy Chappy
Once I have made the space I will retry my RTL Transmissions because they do suffer from cramped surroundings.. but like I said they need upgrades they have had "Bad previous owners"
#9 |
Happy Chappy
#10 | |
A piece of foam port length x 3xdia can be folded into a tube and inserted into the port, where it will be self supporting, this will detune the port, tightening the bass somewhat. rgds, sreten.
| Winisd formula to simulate room gain ? | Old'n'Cranky | Multi-Way | 4 | 3rd April 2011 10:49 AM |
| Need a Sub Enclosure for a 21FT Formula (Cuddy Cabin) LOTS of room to work with! | illtww | Subwoofers | 15 | 15th April 2010 09:43 PM |
| Speaker Class (type) vs Room Size | jomor | Multi-Way | 6 | 26th August 2005 11:44 PM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| Page generated in 0.10822 seconds (87.86% PHP - 12.14% MySQL) with 11 queries |
