Hi everyone,
I currently own a system based on a SE 6L6 amp with fe127e dbr speakers. I find it a bit agressive and bass are not enough precise. Should I buy a subwoofer or start from scratch ? Personally I think I should start from scratch building a 2 way system. What I am looking for is a pair of bookshelves under 500$ dollars. I mostly listen to rock, violin, piano but I also enjoy voices. What do you think ? Simon |
#2 |
It depends how much effort you want to go to. If you do add a woofer you will be helping the Fostex as well as your bass. Are you using any filters with the fostex?
#3 |
Hi AllenB,
Yes I use a RLC filter to attenuate the high frequencies. I see what you mean, with a subwoofer, it could do the job ? Simon. |
#5 |
Right... Thank you then.
What should I do ? Ask for moving the thread in the sub forums or do a new one there ? Thanks again. |
| 2-way design from scratch | Arty | Multi-Way | 0 | 27th February 2011 09:18 PM |
| My first Class D from scratch... | thefish | Class D | 22 | 13th July 2008 08:13 PM |
| Dynaco from scratch | TubeMack | Tubes / Valves | 25 | 2nd September 2006 06:20 PM |
| First build from scratch. | castlesteve | Tubes / Valves | 0 | 29th January 2004 03:33 PM |
| Starting From Scratch... Would love some pointers | Spadge | Multi-Way | 12 | 10th January 2003 02:09 AM |
| Page generated in 0.07593 seconds (72.43% PHP - 27.57% MySQL) with 10 queries |
