I found the information on a Japanese ALE dealer's website. These parameters did not necessary come from ALE.
Check out this link: http://ns.tachyon.co.jp/~sichoya2/ale/woofer.html WA-4000 Woofer Specifications Diameter: 40cm (TAD1601b compatible), Bandwidth: 26 to 1KHz, Impedance: 8 Ohm, Maxmum Input: 100W, Output Sound Pressure Level: 98dB, Magnetic Density: 15,800 gauss, Weight: 25kg, Note: alnico magnet, Made in Japan WA-4000 T&S parameters Fs: 34.57Hz Qms: 5.15 Qes: 0.23 Qts: 0.22 Vas: 33.66(liter) Re: 5.11(ohm) Mms: 65.26(g) Cms: 325(um/N) Bl: 17.58(T.meter) What seems strange to me is that how can the Vas be 33.66 liters. That is VERY low. The Cms is also VERY low. The Fs is 34.57Hz but the specs said the Frequency Response is 26Hz-1000Hz. Is it even possible that the Frequency Response is below the Fs? Thank you guys in advance. Man Last edited by manp111; 15th August 2011 at 06:13 PM. |
#2 |
pictures
#3 |
For me clearly a missprint. This value for VAS seems to be cubic feed instead liters (multiply the value by 28). That means 900 liters instead 33 liters.
What actually the manufacturer says to that value? Have you already ask there? e-mail is follow: jack@mtc.biglobe.ne.jp Last edited by tiefbassuebertr; 16th August 2011 at 10:42 PM. |
#4 |
That is a valid point.
It is a Japanese manufacture so I think it uses metric. The Vas could be 336.6 liters instead. The Cms doesn't seem right either. |
#5 |
Thanks for pointing out the email. I didn't think about email him because he is not the manufacturer. I emailed him.
#6 |
What do you guys think of the Cms? Can the Cms be 325 micro meter?
#7 |
Why not measure it (the T/S parameters) yourself?
[p] Chances are the manufacture's published numbers are not that close to the actual numbers anyway. |
#8 |
I don't know how to measure. Plus I am kinda lazy.
I might have to learn if I can't sort out the given figures. |
#9 | |
Vance Dickason's The Loudspeaker Cookbook is an excellent resource on how to do this with a minimum of tools. Parts Express sells the WT3 woofer tester that does this in an automated fashion for about $100. There are other tools like Liberty Instrument's Praxis that can be free if run in Demo mode. Praxis will measure T/S parameters with a minimum of invested hardware. Liberty Instruments, Inc. Home Page |
#10 |
Thanks for the information. I will looking into it.
I am just trying to figure the box size and it seems like the Vas is necessary. |
| ALE Acoustic WA-4000 Woofers Thiele Small Parameters | manp111 | Multi-Way | 2 | 16th August 2011 11:39 PM |
| Thiele - Small parameters | tomtt | Multi-Way | 0 | 25th March 2009 02:48 AM |
| Thiele-Small parameters guide | anli | Multi-Way | 3 | 7th May 2006 11:38 AM |
| Thiele-Small parameters | Hoffmeyer | Multi-Way | 6 | 15th March 2006 01:12 AM |
| Hartke 15XL8 Thiele/Small Parameters? | spence | Subwoofers | 5 | 27th February 2006 08:10 PM |
| Page generated in 0.10071 seconds (76.33% PHP - 23.67% MySQL) with 11 queries |
