Since I don't have the resources (at this point) to go all in on obtaining a full loudspeaker testing set-up, I was wondering if anyone tried this approach; purchase something like the Behringer CX3400 active crossover a few small power amps and a pre-amp and attempt to determine an accurate crossover point by experimentation (by ear). Is this a feasible approach? It seems like this approach would not be very expensive and it would also allow you to utilize it as a active system.
#3 |
Yes, a lot of folks do this. But if you want to do it "really right" you'll use something like the DCX2496 which will allow you to set different slopes/orders and underlap or overlap the points. That can be very important to advanced crossover design.
With the CX3400 I think you can spread the frequencies some, but you'll always be stuck with L/R 4th order. If that's what you want, then no problem. And it's much faster.
Take the Speaker Voltage Test! |
#4 | |
frugal-phile(tm)
)dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
DCX is a very good way to do this but preferably with measurement gear. Are you intending to find crossover points and then build a passive crossover as I would strongly suggest keeping the DCX and running active..
I would never go back to passive since going active!! |
#6 |
Speakerholic
If you do decide to go active then you can go with the CX3400 or CX2310
#7 |
I'd also recommend staying active.
I even think that active with cheap&cheerful (as opposed to cheap&nasty) amps will sound better than passive with an expensive amp. In an active setup an amp with a damping factor of 70 would have probably more control over the driver than an amp with a DF of 400 or more in a passive one. |
#8 |
Sure it can be done (and probably should be tried at least once as an exercise), but there's a real possibility of your excitable and fickle brain leading you very astray and into Bose territory.... (but having a 'reference' loudspeaker to target might help keep things manageable)
#9 |
Ain't that the truth, Anderson! So many choices can drive you mad. You'll end up tweaking for years. Of course I wouldn't know about that.
I've just gone back to a passive crossover from my modified DCX and am very happy. Not tempted to go back to active.
#10 |
there is some software that can manipulate soudcard outputs to act as a simple programmable active crossvoer, and can do lvl adjustment, and different slopes, yadada.
you can use it to find nice crossover point, but afterwards building a passive xover based on it.. will be quite different. as passive crossover elements tend to be more tha what one needs |
| crossover points | ddoyle | Multi-Way | 1 | 16th December 2006 09:33 PM |
| Determining crossover values | Peter vdP | Parts | 2 | 12th November 2003 12:26 PM |
| What are the common audible crossover points? | dih1118 | Multi-Way | 2 | 22nd September 2003 09:12 PM |
| Do crossover points really mess things up? | BAM | Multi-Way | 3 | 2nd June 2002 05:57 AM |
| crossover points | ogp | Multi-Way | 1 | 17th January 2002 10:20 PM |
| Page generated in 0.19461 seconds (53.66% PHP - 46.34% MySQL) with 10 queries |
