Old 15th August 2011, 12:54 AM   #1
ro9397 is offline ro9397  United States
Default HiWave 2" BMR12 full range x4 + tweeter TBD
Considering using 4x HiWave 2" square full range drivers (estimte 150 - 10 kHz sans Xo) + tweeter TBD.
4x 2": 89 dB, 8 Ohms, 96 W peak, 108.5 dB peak.
This project is subject to the trash bin till driver samples and/or graphs arrive (due shortly).
Xo: LP/HP 1st-order @ 3 kHz (2" will be 12 dB down @ 12 kHz). One goal is matched horizontal radiation patterns in the 2"/tweeter overlap range (I've heard such speakers and very much like the effect).
The 2" driver is 2.6" outer dimension. Two centers spaced 2.7" phase cancel at estimated 10 kHz (please correct if necessary). The 2" dimension accommodates almost any array. Will consider second LPXo on two 2" drivers to minimize phase cancellation at higher frequencies.
This is my preferred array:
Four in perfect, tight square, baffle cut vertically in half, angle the two halves inward to cross fire some point in front of the speaker. What is preferred V angle or what is preferred cross-fire point relative to listener? The tweeter centers horizontally vs. the four 2", immediately above the four 2", on separate forward-firing baffle. The tweeter face vertical plane is the "V" intersect point of the two 2" baffle halves.
Anxious to read your preferred alternate array and alternate Xo suggestions.
How much air will these four 2" move in octave 125-250 Hz vs. Dynaudio 160 mm Esotec?
TIA!
Jimbo
"Television is the poor man's whiskey." Russel Baker
Are coaxial/triaxial speakers considered "Full Range"? sprinter Full Range 41 26th February 2011 02:02 AM
FS: Full Range Enclosures (19"w x 10.5"h x 12"d) axissilverhand Swap Meet 0 19th December 2010 12:01 AM
OGIaudio - True Ribbon - Full Range OGIaudio Planars & Exotics 37 28th September 2010 04:36 AM
FS: Apogee Caliper Signature full-range ribbon speakers andyjevans Swap Meet 1 22nd September 2010 11:33 AM
Full Range drivers - do they always "rip your ears off" at high volumes? chris661 Full Range 52 16th December 2009 08:25 AM
Page generated in 0.06087 seconds (71.01% PHP - 28.99% MySQL) with 10 queries
