Horn driver needed help finding one?
Old 14th August 2011, 09:44 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default Horn driver needed help finding one?
I need a driver that has the following parameters for a horn clone build! So far this driver has eluded me! See if you can guess the driver I'm trying to find a replica of?
I need,
Fs 26Hz
Qts 0.2
Qms 2
Qes 0.22
Vas 350l
SPL 95dB
All in a 15" driver.
Audio projects and more: gswdh.co.uk
Old 15th August 2011, 02:19 AM   #2
whgeiger is offline whgeiger  United States
For a base horn driver, pick from one of these:
Precision Devices International Limited
The 18" and larger versions are interesting as well.
WHG
Old 15th August 2011, 02:36 AM   #3
R.I.P.
The specs look very Tannoy, and its not that hard to find
similarly specified professional drivers at the higher end.
rgds, sreten.
Old 15th August 2011, 03:49 AM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Altec 416 or 515?
planet10 needs your help:
Let's help Ruth and Dave
Old 15th August 2011, 08:12 AM   #5
Thanks looks good I want to build replica horns that use the Monitor Gold, just checking what sort of cost I'm looking at.
Old 15th August 2011, 12:52 PM   #6
GM is offline GM  United States
GM's Avatar
Originally Posted by Cal Weldon View Post
Altec 416 or 515?
Vas is way too low for the low Fs versions. My 515Bs are around 600 L and I've seen them as high as 1 K!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th August 2011, 07:51 PM   #7
el`Ol is offline el`Ol  Germany
Two of those?
accutonŽ Carefully selected loudspeaker drivers.
or three of those?
Or this?
http://www.fertin-acoustic.com/hp_38ex.php
Sorry, I'm kidding.
Old 15th August 2011, 09:23 PM   #8
That last driver is awesome though
Horn driver needed help finding one?Hide this!Advertise here!
Help finding right driver omnivore Multi-Way 13 17th February 2011 03:59 AM
Need help finding a specific driver. Rick J. B. Full Range 0 28th December 2006 12:55 PM
Finding the volume of a driver wigginjs Multi-Way 9 7th April 2004 11:31 PM
Help needed for finding Aleph parts! louischia Pass Labs 11 25th January 2003 06:17 AM
need driver finding help trespasser_guy Multi-Way 10 18th December 2002 06:40 AM
