3 way using woofer plus ciare coaxial - Page 2 - diyAudio
Old 14th August 2011, 08:00 AM   #11
Brett's Avatar
obi, the B&C 8CX21 and 8CXT are well regarded and used in some Seaton and Danley product.
Pro Sound Service in the US are the distributor, have good prices and excellent to deal with. Good shiiping prices to down here too.
If my other designs had worked aout a bit differently, I was going to get some of the 8CX21 to go with 2225 for surrounds. All active of course.
Old 14th August 2011, 08:26 AM   #12
obiwan is offline obiwan  Australia
Thanks el`Ol. I don't mind a sealed enclosure, in fact it would be preferred I think seeing as I'm going to blend it with a separate bass driver below say 300 Hz.
Old 14th August 2011, 08:27 AM   #13
I'll check out the B&C drivers Brett. Bathurst this year, I haven't checked out that ridgy didge website again in a long while?
Old 14th August 2011, 08:32 AM   #14
el`Ol is offline el`Ol  Germany
With the NDCX 12-1.4 one could be sure that one doesn't have compression in the woofer section and the Ciare home gear probably isn't available down under anyway.
Old 14th August 2011, 08:32 AM   #15
AllenB is offline AllenB  Australia
obiwan, is this Bathurst thing a private do? Do you have the address?
Old 14th August 2011, 08:37 AM   #16
With a three-way solution without having listened, however, I would take the BMS 12"er with "real" horn Overview
Old 14th August 2011, 08:45 AM   #17
Yeah, its a private thing held on the Bathurst Race weekend, or at least that's when its normally been on. I've been to 2 or 3 of them. I'll have to log on to the website again on my work computer because on this one I don't have the password saved, I haven't looked at it in 6 months or so. It is a great weekend, some go to the races during the day, but everyones there at night time playing music on various home made speakers and amps etc. And noone is too precious, its all no nonsense hifi, music and drinking, no wank factor. I'm not sure how many terry might be having around or if i can get you an invite, I'll have to log on and see if its even still happening because I haven't had any emails in a long time.
Old 14th August 2011, 08:49 AM   #18
Brett's Avatar
Yeah, it's still on 7/8/9/10 Oct. I'd hoped to get up there this w/e too, but got offered some O/T and the money talked. Might be best to email the Godfather and see how it's holding up for places.
Old 14th August 2011, 09:03 AM   #19
Yes Brett, I better email the Godfather again.
el`Ol, I assume you'd probably cross that BMS 12/horn at around 1kHz. I just wonder how good say the 500 to 1000Hz range will sound when mostly blocked by the horn in front of it.
Old 14th August 2011, 09:07 AM   #20
Ok, I respect that but if you can, then I'll take it seriously. I have nothing against hifi, music and drinking, and I live within cooee of Bathurst so I won't need the races as an excuse. See how you go.
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 10:50 PM
Need WinISD help from Woofer Tester results! 8" In-Wall Coaxial to Sealed or Vented! CZ Eddie Multi-Way 8 2nd August 2011 01:30 PM
Ciare 6.38NdW krips Multi-Way 4 15th September 2009 02:06 AM
Has anyone tried the Ciare 8.50 NdMR or the Ciare 6.38 NdMR in a front horn? pk Multi-Way 6 10th January 2009 09:42 AM
Active coaxial 3-way speaker with linkwitz transform woofer alexclaber Multi-Way 3 7th August 2008 09:42 AM
Copyright 1999-2017 diyAudio
