Got an old pair of Jmlab 703 Opium speakers.
I hope someone over here knows these old guys.
One tweeter and one mid are broken.
I haven’t the slightest idea where to find those speakers and if the 703’s are worth repairing.
A lot will depend on the price of course.
The mid has the following label:
3” dome
H204 8ohm 25/87
Made in Norway.
The label on the tweeter goes like this:
Focal ref T101
Nr. 740036
Technologie d’avant-garde (Just to be complete and it sounds funny)
I didn’t search the net for now, first wanted to know what you speaker experts think.
I can always post some pictures for reference.
Greetings
/Hugo
3” dome
H204 8ohm 25/87
Made in Norway.
Focal ref T101
Nr. 740036
Greetings
/Hugo
The mid dome is a Seas 3'' dome. You can get the info on
http://www.seas.no/Gamle chassier pdf/3 dome H204.pdf
Unfortunately, it is out of production for a while i think but maybe you could use another 3'' dome with some tweaking.
F
F
Thank you, that's exactly the same speaker.gary f said:The mid dome is a Seas 3'' dome.
Now, for your info, here's a picture of the backside label.
Could you possibly point out replacements for the Seas and the Focal?
/Hugo - not a speaker expert.
I think you could easily use the vifa D75MX-41-08, it's a 3'' dome, almost same sensitivity, fs, BL and Sd. Same rated power too. It cost 39.50 US$$. It is almost plug and play!
For the tweeter, I don't know the caracteristics of the Focal so it's a little risky. You could always buy any tweeter you like and fix the crossover by ear or with some measuring equipment.
Good luck!
F
Good luck!
F
Banned
Joined 2002
For your pleasure, and with an old Stanford 4 channel PA-amp
Found a Focal tweeter who would fit mechanically.
Unfortunately I can't find any info on the old T101.
Should I take the risk?
http://www.focal.tm.fr/gb/compo/tweeter/pdf/TC120TD5.pdf
/Hugo
/Hugo
- Jmlab 703 Opium. Repairable?
