Old 6th September 2011, 03:10 PM   #281
Here's some data for the equalized "double cone":
The problem with this device and/or driver is lots of resonances:
Not sure if this is worth pursuing.
Markus
Old 6th September 2011, 03:30 PM   #282
Markus,
Have you done some distortion measurements as well, comparing the speaker with and without deflector? I did a quick test some pages ago that pointed into that direction, but it would be nice to have a second measurement from a different setup.
vac.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
Old 6th September 2011, 10:52 PM   #283
ScottG is offline ScottG  United States
It's remarkable for a single full-range driver, but I don't think it's ever going to be "it".
On the other hand I think some of the effort of the design could well be beneficial.
For instance the overall uniformity of pressure loss off-axis from 1-4 kHz is pretty good, not excellent (that 1.8 kHz artifact needs some work), but still pretty good when you consider that this range posses difficulties with larger drivers.
Below 1 kHz (and particularly below 700 Hz) you can improve the uniformity with a leaky vent on the same baffle as the driver but at its "rear" (considering it's a radial design). This will of course limit it's usefulness as freq.s decrease.
Above 4 kHz - well, that's always going to be a problem (at least with regard to a uniform drop in pressure off-axis, and overall linearity). I think you'll have to transition to another driver(s) to get something more uniform. (..even then though, the response is still pretty good on an absolute-level to more than 10kHz.)
I wonder what it looks like when you eq. it on the dominate axis you listen to?
perspective is everything
Old 7th September 2011, 08:23 AM   #284
I let a DCX2496 do the heavy lifting (878Hz, -9.6dB, Q1.8; 1.88kHz, 11.2dB, Q2.83; 2.44, -10.5dB, Q7.9) and then run it through Audyssey MultEQ which does a pretty good job at speaker correction. After that, the speaker sounds pretty good.
A smaller fullrange driver would probably help with the 1.9kHz region but then we're talking about a two-way design which brings in additional complexity.
There are also traditional two-ways that are even more omni: audio blog: Review of Polar graphs
Markus
Old 9th October 2011, 03:23 PM   #285
6.283 is offline 6.283  Germany
Here are some omni insights hot off the press. Enjoy the lengthy text with your favorite beverage.
http://www.2pi-online.de/html/interim_conclusions1.htm
Oliver
2Pi-online.de
The acoustic summation of multiple drivers StigErik Multi-Way 18 15th January 2010 08:05 PM
How can I find effective piston area? mstar Multi-Way 14 22nd June 2006 05:50 AM
Acoustic Research Drivers Gavin_mi Multi-Way 2 5th September 2005 12:14 AM
(FS) Boston Acoustic replacement drivers (PSB's also) feke67 Swap Meet 0 6th October 2003 10:11 AM
Acoustic centres of drivers/measuring RobWells Multi-Way 15 15th September 2002 08:15 PM
Page generated in 0.08768 seconds (76.10% PHP - 23.90% MySQL) with 11 queries
