Old 8th August 2011, 07:23 PM   #1
Default 6 ohm woofers in series
I'm considering using Mission cf200/78 drivers (2 per enclosure) to make a set of floorstanders. I'm having trouble finding any TS parameters for them.
I know that they're 6 ohm impedance, so I wanted to know what effect there would be by connecting them in series? ie, sound, performance, power handling etc..
Cheers, James
Old 9th August 2011, 05:23 AM   #2
jerome69's Avatar
It is easy to measure the T/S parameter. You need a PC computer, a sound card with a line input, a resistor (33 or 500ohms) and a mini jack to jack
See my tutorial.
Woofers in series, almost same in parallel but double impedance, same SPL.
Old 14th August 2011, 08:34 PM   #3
Cheers, James
J,
If DCR = 6 Ohm then Nom Imp. = 8 Ohm.
Parallel connection is preferred so long as the amp you use can handle a nominal 4 ohm load. You want to avoid the addition of impedance peaks that occur at driver (system) resonance.
Enclosure design should be based on measured driver TSP's not the published ones. This is the DIY advantage, but measure twice, then cut once.
WHG
WTB: 8" 4 ohm woofers steelyjoe Swap Meet 2 19th February 2011 06:54 PM
DVC Woofers - 4 or 8 ohm? AJ Multi-Way 1 8th June 2005 12:02 AM
Dipole - 4 ohm in series or 8 ohm in parallel? cheesehead Subwoofers 1 1st December 2004 07:53 PM
Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? Cal Weldon Multi-Way 16 21st February 2004 12:31 AM
Dynaudio Gemini clone but with 4 ohm woofers in series OK? NH7RO Multi-Way 1 7th September 2003 02:28 AM
Page generated in 0.07288 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
