I'm rather intrigued by Linkwitz' Pluto omni speakers. I'm trying to reverse engineer them as I would like to replace the Peerless drivers he's using with some Tangband W5-1611SA (because I have the Tangbands handy). At first glance, the Pluto looks like a sealed enclosure speaker. So armed with an enclosure calculator and the datasheet for the Peerless 830873, I arrive at a box volume of 3.53 liter. SL states that the pipe is 4" (10.16 mm) ID, 28.5" (724 mm) long. That's a volume of 5.87 liter. So playing with the enclosure calculator some more, I arrive at a Qtc = 0.60 for the Pluto as built. So if I am to build a Pluto-like speaker that fits the Tangband W5-1611SA, would it be reasonable to plug the values above into the calculator and use that as a starting point? Or am I barking up the wrong tree here? I'm not quite sure that my initial assumption of the Pluto being a box speaker is completely valid and would appreciate some input from the more experienced speaker builders here. ~Tom |
#2 |
You need to do some reading on SL's website!
The speaker has to be active to work properly, or be prepared to build an inefficient power sapping passive crossover to marry the drivers if you plan to go passive. Then with passive you need a LOT of power so forget tubes/valves. The speaker is a closed box design. It is actively equalized to produce more bass in the low end than would be expected from a small bass mid. For this purpose you need a very long throw low distortion drive unit. Pluto uses a low crossover point unsuitable for normal tweeters. The treble drive units needs to not have a faceplate, that will ruin the broad dispersion. The peerless driver went years ago, it was only used for Pluto 1, Linkwitz is now on Pluto 2.1 with far superior bass performance. Pluto uses a custom version of a Seas drive unit made specifically for the design. This bass drive unit could be successfully replaced with an inevitably more expensive unit. The treble drive unit should really be the same Aura whisper drive unit. You may get away with a peerless 2 inch fullrange like in the Platon pluto copy but this has more narrow dispersion. Interesting DIY Pluto and Orion: Platon If you do attempt to copy Pluto keep the speaker as slim as the drive unit basket, it is meant to be a point source. |
#4 |
Rob, you don't because that defeats the entire purpose of the design and from first listening tests it is absolutly not required although not visible in any diagram or datasheet. If you want more highs then another FR is required. But as things stand now you need to roll off the highs anyway otherwise it will sound too bright.
Cheers Oliver
2Pi-online.de |
#5 |
Hi Oliver,
Maybe my memory is faulty, didn't you discuss adding a tweeter with this Speaker? Anyway that is good to hear, if you can get away with equalization alone. Perhaps you should link this discussion with the omni popularity thread! |
#6 | |||
then I would try to make them more popular since they're worth it.
2Pi-online.de |
#7 | |
...but since I am here anyway, I have a few comments on topic:
Tom, the TB W5-1611SA has an underhung motor and I am not sure it can produce enough punch below 100Hz. If you believe data in datasheets then it might. However, it would easily find its limits in excursion capability, which are required down there. So you would have to add a sub, which is primarily not required with Pluto. Also, the PP cone is too floppy for usage without sub. Then you need either a rigid metal or otherwise stiff cone. Dried paper, Nomex and Kevlar come to mind. The "special" Seas unit is really the best out there for the money since years. Quote:
In short: If you want to listen to music and be done then you should buy plans from SL. The speaker is absolutely worth the money. If you want to fiddle and learn, well, then nobody can stop you anyway. But then be prepared to do measurements otherwise you will not hit the mark. Cheers and have fun ! Oliver
2Pi-online.de |
#8 |
I see Demokrit has become a two way now, just not in the direction I imagined!
This might make a nice surround speaker for multi channel omni with Pluto. |
#9 | ||||
1) compensate for driver resonances/squiggles in the frequency response 2) extend the low end Nothing says I can't do that as well. I'm well versed in analog filter design and own the test equipment needed to engineer them, so no issue here. What I don't know much about is speaker design. That why I posted this thread to start with. I have the W5-1611SA's and was wondering if they could be used in a Pluto clone. I'd probably use the AURA tweeters for the same reasons as you point out. I'm not looking to start a tube vs sand yelling match. How much power is needed depends entirely on the desired SPL in the room where the speakers are located. Along with speaker efficiency, of course. I'm not looking to rock my house off its foundation. If an LM3886 can power the Pluto, I'm sure a 6L6 Push-Pull stage would be able to do so as well. The guys at the Parts Express Forum actually made a passive Pluto. No word on efficiency - at least not according to my quick glance-over, but the frequency response is pretty nice... Quote:
~Tom |
#10 |
Oliver,
Did you do any polars for your deflector/speaker combination? I just measured a quick and dirty deflector on a B200 today and it didn't look too promising.
Markus Last edited by markus76; 8th August 2011 at 10:09 PM. |
| reverse engineering.... salvaged components | kita | Everything Else | 10 | 25th October 2008 09:48 PM |
| reverse engineering a box | Zero Cool | Multi-Way | 1 | 16th July 2007 10:00 PM |
| reverse engineering a crossover? | BlackDog | Multi-Way | 30 | 9th December 2005 03:01 PM |
| Svante, a reverse engineering problem | sreten | Multi-Way | 16 | 4th April 2004 05:38 PM |
| Page generated in 0.13270 seconds (83.22% PHP - 16.78% MySQL) with 10 queries |
