Hi There!
I'm about to make an adaptation using the excellent Beyma T2010 tweeters on my Northridge E60 JBL Speakers. After some stupid abuse, I've blown the original tweeters. OK, sh*** happens, but I was surprised when I removed the cover and I found a very small tweeter in there, which was 4-Ohms! Digging deeper, I found more weird things. The crossover for the TW is just a 2.5uF capacitor, that if I'm correct, will provide a 16khz cut 6Db/oct for a 4Ohms driver. The owner manual says that the crossover frequencies are 1000 Hz and 4000 Hz. So, what the heck?! I've attached the crossover schematic, it is 100% reliable as I drew it myself and I measured the inductors. I couldn't figure out the frequencies, neither the type myself. I was hoping that you could help me figure that out! By the way, why would the tweeter be 4Ohms if the rest is 8Ohms? Why would the midrange be inversed? What are the actual xover frequencies and type? Thank you very much! Best Regards |
#2 |
#3 |
Yes, it did! Basically the E60s are crippled from factory by a shocking bad crossover. The Mid isn't there because of a 7R5 attenuation resistor. There's a lot to work on them, but they really have potential to sound awesome! Will just require a measurement tool and time to work on it.
#4 |
I think the majority of inexpensive manufacturers use crossovers like this, I've got a pair of Cerwin Vega 3 ways in the basement that have I think 4 or 5 parts (if you count the fuse) on the crossover that's glued to the terminal cup, and another pair of Altec Lansing outdoor-type speakers that I'm using for my surround-back left and right that have only a capacitor on the tweeter if I remember right.
#5 |
Yeah... But 4-Ohms tweeter is really TOO BAD! E60's arent that cheap anyway...
#7 |
In a 8-Ohms loudspeaker?
#8 |
Sure, the speaker can be labeled as 8 ohm nominal impedance, but at any given frequency the impedance moves around quite a bit. Chances are the amount of the frequency spectrum that the tweeter covers in a 3 way wasn't significant enough to change their rated average impedance.
They probably just got a better deal on the 4 ohm version and figured it wouldn't alter the average impedance enough to be of concern. |
#9 | |
Yeah, but they were receiving twice the power, consequently, they toasted.
Anyway, apart from that, I would like to show you all how the E60 are "capped" of its true potential. Attached are the service manuals of borth E60 and E80 loudspeakers. You can observe that the Mid-range and Tweeters are the SAME for both. The only difference is that the E80 uses 2x 6" woofers instead of 1x 8" of the E60. Anyway, that does not justify the HUGE crossover difference. The E60's manual claims that the crossover frequencies are 1000 and 4000Hz. CLEARLY the crossover frequency of the tweeter is not 4k, but it is 16k, as it uses a 2.5uF cap on a 4-Ohms tweeter. The Mid-Range is too much attenuated with a 7R5 resistor, that's why it has reviewed as pointed out from our friend erjee: Quote:
I think I'll hear a GREAT improvement! |
#10 | |
The crossover frequency of the tweeter may very well be 4khz if the impedance of the driver in that range is high enough. You'd have to measure the drivers frequency response and impedance curves to know for sure, simply changing the crossover component based on the nominal impedance airbrushed on the back of the magnet probably won't yield very good results at all. |
| Yamaha NS-8390 crossover frequencies - strange? | ray_moth | Multi-Way | 2 | 10th April 2012 12:31 PM |
| jbl E60 northbridge | sakis | Multi-Way | 2 | 19th January 2008 09:04 AM |
| JBL E60 Speakers | -_nando-_ | Multi-Way | 12 | 18th March 2006 02:57 PM |
| laser substitute for MF E60 | distortion | Digital Source | 1 | 19th July 2005 02:24 PM |
| Diaural crossover really strange.... (to me atleast) | hifi | Multi-Way | 3 | 9th July 2002 03:29 AM |
| Page generated in 0.11028 seconds (85.35% PHP - 14.65% MySQL) with 11 queries |
