Old 6th August 2011, 04:26 PM   #1
60ndown is offline 60ndown  United States
Default 3 way crossover help please
my latest project is a *high fidelity* bass guitar speaker, something i can play at home that will have hopefully much better tone then your average bass guitar amp/speaker combo.
weather its right or wrong in theory i want to use a 3 way cross over.
i purchased and received this recently,
INFINITY REFERENCE 60 3 WAY PASSIVE CROSSOVERS 4ohm NEW - eBay (item 390293772393 end time Aug-28-11 16:23:48 PDT)
it has 2 separate outputs for the woofer (as the speakers it is designed for used 2 x woofers) i failed to notice this before purchasing
my question is,
can i use just 1 woofer output or can i somehow use both outputs connected to 1 woofer, and what would that do to x over point and slope and ohms that the amp would see etc???
id like to be able to use 200 watts on the woofer section (which is what the 3 way x over is rated at)
any help/advice appreciated.......
Old 6th August 2011, 04:45 PM   #2
Well...using a passive crossover with drivers it wasn't designed for won't work as expected, rolloff slopes and driver levels probably won't be right. Since that crossover is rated for 4 ohms, they are most likely using two 8 ohm woofers in parallel, so I'm guessing if you hook up one 4 ohm woofer it will "work". Having said that, if you allready have everything, no problem trying it to see how it sounds.
Mike
Old 6th August 2011, 04:47 PM   #3
A passive crossover is designed to be used only with a specific set of drivers. An active crossover can be used with any drivers.
I suggest you look in to and buy the latter type and some amps, or learn how to build a proper passive crossover (not easy).
-Charlie
Old 6th August 2011, 05:04 PM   #4
Mike
thank you,
do you mean connect both the 8ohm outputs to 1 x 4 ohm woofer?
or just 1 output?
the problem i can see is blowing up my amp if i show it some crazy ohmage
Old 6th August 2011, 05:37 PM   #5
If I'm right, it won't really matter if you use one or both as long you keep polarities correct, so try it with just one lead to the woofer.
Mike
Old 6th August 2011, 05:47 PM   #6
so if im understanding this correctly,
the woofer section of this crossover behaves *more or less* the same if i connect,
2 x 8 ohm woofers to both woofer outputs, (shows amp 4 ohms)
or
1 x 4 ohm woofer to just 1 woofer output? (shows amp 4 ohms)
makes sense to me 'kinda' ??
Old 6th August 2011, 06:38 PM   #7
You got it.
Old 6th August 2011, 07:03 PM   #8
You got it.
thank you ill try it and report back w my findings.
Old 7th August 2011, 05:29 AM   #9
Francec is offline Francec  Australia
Banned
Which other drivers are you using? a mid-range that will cover 250 to 4,000 Hz won't be cheap.
To crossover or not or ? asiquis Multi-Way 17 15th November 2009 03:52 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Help with first crossover Vikash Multi-Way 7 23rd January 2004 11:52 PM
Page generated in 0.09063 seconds (86.84% PHP - 13.16% MySQL) with 10 queries
