Old 6th August 2011, 04:05 PM   #1
Default Audio Technology 10 C 77 25 10 KAP Advice
AT Sandwich cone unit I m thinking about .
Anyone that have tried this new woofer from AT collection.
Can anyone advise me if I can use that 10 " driver ( 77 mm VC ) up to 800 hz?
Will it play clean up to the 800 mark for me or is it better to use a midbass ?
thanks guys
Old 6th August 2011, 05:57 PM   #2
jerome69's Avatar
Hi Dom !
No problem to use them till 800Hz.
I think, in your active system, it is better to use a mid bass, to separate bass (<150Hz) to midrange (>150Hz).
Cheers.
Old 6th August 2011, 06:27 PM   #3
So better still use a dedicated Midbass driver like the Volt BM 2500.4 correct ?
I just thought simpler 3 way would be better 10 s 3" dome and tweeters ?
cheers
Old 6th August 2011, 07:38 PM   #4
jerome69's Avatar
Yes a dedicated midbass is better.
But ATC makes a system with a 12" + 3" + 1"
ATC Loudspeakers. SCM50SL AT
Old 6th August 2011, 07:42 PM   #5
ok 4 way it will be
I thought if I went with a 10 " bass 77 mm VC that would be able to do good midbass too?
I guess one driver covering too much frequency is not good ?
cheers
Old 6th August 2011, 07:58 PM   #6
jerome69's Avatar
Yes a 10" can do midbass.
But i think to do midbass a 8" is better (150-800Hz).
In this forum yes
I think 3 octaves is a good value, 5/6 octaves is a maximum and above ...
Old 6th August 2011, 09:00 PM   #7
Hi domtweaker
Have a look at this link. It might help you decide what to do / expect. Please note that the shown T/S-data are not necessarily final.
10C77
Karsten
Old 6th August 2011, 09:03 PM   #8
thank you I have seen that before
sounds very promising indeed
Old 6th August 2011, 10:10 PM   #9
It´s interesting to see that according to the measurements from the above link, the burn in process burned about 2g fat form the drivers := O -hopefully they´ll be a bit more long lived than that
haha -Just reminds us that these data needs to be taken with a pinch of salt. The official specs states 54,5g mms which is about 8g less than these measurements suggests.. Could AT really be so far off? they probably knows what the moving parts weighs, so....
I can assure you though that these woofers goes deep and does so with great impact and control.
It´s also interesting to see how much more these AT´s puts out in the upper bass region than the SS and Seas which it were compared to. This could account for the comparably great sensitivity i have experienced with it in my 54L ported enclosure. The SS really looks generally insensitive compared to the seas and the AT. Food for thoughts
You know my stand on the appropriateness of these woofers midrange capabilities. Best be avoided, but at the same time simplicity is maybe an even greater concern... I could be that it does better with the small ATC dome than my 7" mid/bass so give it a try it may fit with the ATC quite well after all... 800Hz is probably a stretch though... Is it because the ATC dips or? it has been crossed with 12" woofers at 380Hz in several constructions some even by ATC themselves
cheers
Old 6th August 2011, 10:19 PM   #10
Ha ha that is funny woofers are burning off some extra calories !!!!
There is always + /- to everything for sure.
I will try a listening test and see how they sound up to 800 hz in comparison to the BM2500 .4 units which some say is the ultimate midbass driver.
those are sexy drivers Oh boy .
Audio Technology 10 inch woofer question domtweaker Multi-Way 3 13th July 2011 03:42 PM
SEAS 25 F-EW 10" woofer Daytona50 Swap Meet 0 21st June 2010 07:03 PM
10-25 hz, is it necessary for HT or Music? Daveis Subwoofers 236 26th October 2008 02:31 AM
Qtc for the Flexunits 12 B 77 25 10 Tomv Multi-Way 2 12th December 2007 09:02 PM
Page generated in 0.09961 seconds (78.33% PHP - 21.67% MySQL) with 10 queries
