Old 6th August 2011, 01:03 PM   #1
Bill poster's Avatar
Default can speaker cable current power an electric motor
I want to have a powered flap/cover over the drive units for my next build- they open when the amp powers up etc. Any advice on how I do this- what motor to use?
Cool Loudspeakers Facebook group
http://www.facebook.com/media/set/?s...24506880902633
Old 6th August 2011, 02:32 PM   #2
18Hurts is offline 18Hurts  United States
I would use the switched outlets on your receiver or pre-amp to power up a DC power supply (wall wart etc) You can do it with two leaf switches, or for more exotica--optical sensors to tell if it is open or closed.
12 to 14.4 VDC automotive drive motors will work well with a wall wart type power supply, just make sure the amount of amps the wall wart puts out is at least double the motor current rating.
If you don't have switched outlets, then it gets a little tougher. The power light on the amp can trigger a light sensor to trigger a relay to drive a motor. If you do it that way, then use light (infared) and additional optical sensors to trigger the relay to shut off. (two relays) Install backup limit switches to mechanically break the connection if the sensors fail, get dirty etc. If you are really paranoid, the optical sensor can also trigger a timer so if the drive jams, it will time out and shut off the motor protecting everything.
So you are going to put a motorized panel on the front of your speaker for protection (or to hide it) and have it open when listening to music? Interesting...
Old 6th August 2011, 03:42 PM   #3
yes its a flap that covers the drive unit and lifts up- a 'soft' powered type system wd be nice.
I want to avoid any extra wires- maybe a battery powered motor?
Old 6th August 2011, 03:58 PM   #4
AllenB is offline AllenB  Australia
You could 'sense' the presence of a signal in the cabinet using circuitry that buffers the motor from the input.
Western Electric Speaker Cable Musik007 Twin Audio 10 8th May 2012 05:54 PM
Very strong and very small electric motor peranders Everything Else 27 17th January 2010 06:07 PM
electric motor controller Clipped Car Audio 8 10th July 2008 03:02 PM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
Electric motor capacitor for crossover ? djdan Multi-Way 15 12th October 2004 04:10 PM
Page generated in 0.07420 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
