Old 5th August 2011, 06:21 AM   #1
Default which 10 or 12 bass drivers for phl1120 and neopro 5i
gday all
i,m just about to start a new project and need some advice
i will be using a phl 1120 for mid and a neo pro5i for highs which is a fairly common combination i think so no probs there but i want to set them up in a osboune monument style speaker (i have attached a pic) in a wtmw arrangement and am not sure which bass drivers to use
12" or 10" would be nice and no more than $200 each
they will be powered by 2 stereo f4 so need to be fairly efficent
any advise or critique would be much appreciated
cheers sheafer
Old 15th August 2011, 12:58 AM   #2
Originally Posted by slr 5000 View Post
gday all
cheers sheafer
On a budget? Check Out P-Audo next door.
P.Audio System Co., LTD
Australia Distributor
Cannon Sound and Light Pty Ltd.
Mr. Daniel Trevor
Email: admin@cannonsound.com
Would use a BMTMB configuration and add a 2nd. PHL1120 (or better still PHL1370's) and c/o at a lower frequency.
That would allow you to use larger bass drivers to better cover the first decade.
WHG
Old 15th August 2011, 01:29 AM   #3
BMTMB is IMO a pointless domestic arrangement over BTMB unless
you have low efficiency mids, and therefore need two of them.
Simply put due to BSC twin bass drivers match to a mid with the
same sensitivity as each bass driver, but to allow for adjustment
its best to have a mid ~ 3dB higher than each bass driver.
At 96dB for the mid your looking at ~ 93dB/W for each bass driver,
and that is reasonable territory for professional 10"/ 12" bass units.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 15th August 2011, 05:10 AM   #4
Default Non-Issue, Issue
rgds, sreten.
My recommendation is on point, if speech range is to be kept out of the woofers. The efficiencies are already well matched for each alternative so that is not at issue here. A one decade spread is the optimal bandwidth to operate a typical driver. In the case of the LF, this tack will allow more volume displacement where it is needed to reproduce the first two octaves of music.
WHG
Old 15th August 2011, 08:45 PM   #5
doug20 is offline doug20  United States
I have been using Neopro5i/PHL1120 + The TD12S drivers for years. You could use the TD12M for higher sensitivity (losing extension).
AE Speakers --- Superb Quality, Unforgettable Performance, Definitely. is where I buy all my woofers.
I think they are over $200 though
btw, Im a huge fan of the Neopro5i/PHL1120 MT design, nice choices
If you are looking for an XO for the Neopro5i/PHL1120 then you might want to contact Curt C over on HTGuide.com. He has build custom designs with them.
Old 16th August 2011, 12:27 AM   #6
WHG
No. Not at all. IMO ridiculous midband efficiency means huge bass boxes.
It may be on point for a PA system, but not IMHO a domestic system.
You don't seem to be familiar with BSC, "Baffle Step Compensation",
it changes everything regarding domestic driver sensitivity matching.
rgds, sreten.
http://sites.google.com/site/undefinition/diy (see FAQs)
http://www.zaphaudio.com
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://web.archive.org/web/200909021...esigningXO.htm
http://web.archive.org/web/200909022...ve99/Spkrbldg/
http://speakerdesignworks.com/
http://www.htguide.com/forum/showthread.php4?t=28655
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
http://www.humblehomemadehifi.com/download.html
http://www.quarter-wave.com/
http://www.frugal-horn.com/
http://www.linkwitzlab.com/
http://www.musicanddesign.com/
Old 16th August 2011, 05:16 PM   #7
Default Agenda?
BSC, as you well know, is mitigated by diver placement and signal tailoring in the c/o. At say, a c/o frequency of 200 Hz, the onset of BSC is isolated well into MF driver range only, where it can be easily dealt with. When doing this, output capacities of the MF driver(s) must be increased to meet the demands of a lower c/o frequency were BSC is not at issue. You know this as well, so your agenda here has nothing to do with the issues you continue to raise.
WHG
Old 16th August 2011, 05:39 PM   #8
One of the reasons I love using something like the MiniDSP is because it removes the entire BSC issue from the design.
FS: Fountek NeoPro 5i Ribbon Tweeter (Asia) outofthebox Swap Meet 1 6th November 2011 09:04 AM
Onken bass box with 2 Eminence Deltalite ll 2510 10" bass drivers albertli Multi-Way 35 11th May 2011 12:05 PM
Pensil 10.2 or 12 wrt bass extention? Swifty Markaudio 151 25th April 2011 04:40 PM
alpair 10/12 for rock/bass heavy music? fxs Markaudio 13 1st March 2011 06:14 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Page generated in 0.10193 seconds (87.51% PHP - 12.49% MySQL) with 11 queries
