4" for Mini Monitor
4" for Mini Monitor
Old 3rd November 2011, 08:09 AM   #41
inrank is offline inrank  United Kingdom
inrank's Avatar
I had thought about full range drivers, something like the FX120, but does not really work in sealed boxes. Bass problems really are a problem in my room, and the two most successful speakers have been the ATC's and Keesonics. Even the Rega R1's which were designed for small and tight spaces had an uneven response.
Still if i do go with the CA12RCY, there are only two projects i have found similar-
http://hifi-laden.de/hifi/ms_micro_2006_en.htm
http://www.lautsprecherbau.de/Magazi...36,de,90916,33
http://www.humblehomemadehifi.com/do...0HATT_copy.pdf
http://forum.audiofreaks.nl/index.php?topic=14172.0
Old 3rd November 2011, 10:04 AM   #42
GorengGuy is offline GorengGuy  Australia
Wavecor 4inch paper cone sounds wonderful, I paired them with Dayton 1" RS28F softdome. Last year I made a pair of Eekel
Old 3rd November 2011, 10:52 AM   #43
inrank's Avatar
Cool, Anybody used the Scanspeak 10F as a mid bass? been reading up on it again this morning and looks good. Can really find many comments on how they actually sound though!
Old 3rd November 2011, 01:20 PM   #44
R.I.P.
I doen't seem a good idea to me to lash out 300 or so on DIY speakers that
you don't know will work well, if they don't you'll never recoup the outlay.
IMO what you should do is look for good used small speakers. Vented
should not be an issue, as you can always block ports, or do what I
sometimes do, detune them with a foam lining, it works great for
bass tuning I've found, if the boxes are somewhat boomy, and
it also extends the low bass cut-off point.
Look at getting the speakers for less than the drivers would cost you,
if they don't work at least you've got decent parts for other projects.
As an example these could be quite interesting :
SONY SS-B2ED LOUDSPEAKERS Serious little boxes, German-made and UK-tuned | eBay
A day to go, quality drivers (very extended range tweeter), good boxes,
real wood veneer, presumably a proper crossover, probably go for far
less than sourcing similar parts would cost you, worth playing with.
rgds, sreten.
Old 3rd November 2011, 01:43 PM   #45
inrank's Avatar
Yes i see where you are coming from, but I already have some commercial speakers at the moment, and the fact that i am asking on here is that i would like to make my own again.
Old 3rd November 2011, 02:26 PM   #46
R.I.P.
I appreciate that, but it doesn't seem anyone knows what sort of
speakers will address the issues you have, and as you say, its
going to turn out to be an expensive build if you go for it.
Even if someone says I've built so and so, and they sound great,
doesn't mean you will think so, in your system and in your room.
A few years ago I bought a pair of used Musical Fidelity MC2 mk1's
that turned out to suit my system and requirements very well, it
was somewhat fortuitous, I didn't really know that they would.
They were far better for purpose than a pair of ouch expensive
Celestion 5000's with 24" ribbons I was using at the time, and
struggling with, turns out I didn't need to chuck money at it.
So IMO if you have an undefined issue to resolve, it is best to
experiment. The MC2's have foam damped ports, added cabinet
wall damping and a mild tweak to the stock tweeter levels.
If you just want to build something, by all means do.
But what will address your issues seems unknown.
rgds, sreten.
If your chucking money at a small design, the best on the
web IMO is this : http://www.zaphaudio.com/ZD5.html
Alright the driver is one step bigger than 4", it is sealed.
Old 3rd November 2011, 03:27 PM   #47
inrank's Avatar
Righteo. Maybe a wide range driver like the 10F might be best. (cheaper, no crossover)
Old 4th November 2011, 01:28 PM   #48
burgunder is offline burgunder  Denmark
This driver looks interesting WF110WA03 for a closed box.
Old 11th November 2011, 07:54 AM   #49
inrank's Avatar
Well the CA12RCY is go, been listening to the Keesonics for a good week or so now!
They use the Seas 11F-GX-
http://www.seas.no/images/stories/vi...49_ca11rcy.pdf
Which looks extremely similar to the CA12RCY-
http://www.seas.no/images/stories/pr..._datasheet.pdf
The only thing is the tweeter, its a Seas unit H147 i believe, but not sure what would be a good match.
And I want to use the same sized closed box as well.
Next step is to take the crossovers out and see what the schematic looks like.
Old 7th February 2016, 05:53 PM   #50
GOWA is offline GOWA  Canada
GOWA's Avatar
FS: Wavecor WF120BD04 mids
Website
4" for Mini MonitorHide this!Advertise here!
Accuton Mini Monitor stvnharr Multi-Way 1 28th March 2009 10:04 AM
Griffin's Jordan JK92S/AC G2si/G2i Mini Monitor "array" neil_kaye Multi-Way 2 30th November 2006 02:46 AM
The A4 monitor, best mini monitor? KURT Multi-Way 5 26th April 2005 01:34 PM
Mini-Monitor Project Going On gary f Multi-Way 29 20th March 2004 03:45 AM
best midbass for a horn "mini" monitor? E. Billeci Multi-Way 2 13th January 2004 06:46 PM
