I'm going to be bi-amping my mains and I'd like suggestions on the best amp I can buy for about $100. The tweeters are the SB Acoustics SC25STC-C000-4 and are rated to 120W, though I doubt I'll ever run them that loud. Any suggestions? Rack mount would be preferable, as I already have an A500 and will be putting everything in a rack in the end.
#2 |
I was thinking of using the Sure 2x100 TK2050. Do you think this is powerful enough? http://www.parts-express.com/pe/show...number=320-300
Tweeter Datasheet http://meniscusaudio.com/images/SB25STC-4.pdf |
#3 |
What is the signal path before the amplifier ?
Are you going to use passive crossovers after them ? Or some semi-active way ,where the amplifier is limited in its bandwidth by some RC-CR net at its input ? The easiest choice would be an LM 1876 ( or 2 X LM 1875 ) amplifier ,with 20 W or the classic LM 3875 for 50 W ( LM 4780 is stereo ). Any low power discrete amplifier , also an Op-amp driving two darlingtons would do the job . Also ,for being sure that no harming DC would go thru that tweeter , a single supply amplifier with a lowish value output capacitor (470 uF ? ) Last edited by picowallspeaker; 3rd August 2011 at 08:01 AM. |
#4 | |
#5 |
The Sure TK2050 boards are good but the HifiMediy ones are better, also they have speaker protection.
col.
http://www.minirig.org.au |
#6 | |
The tweeters are 1 dB less efficient (91 dB at 4 ohm is 88 dB 1 watt one meter equivalent) than the woofers, so will need another dB of power level to balance. With 100 watts, the tweeter will be at 108 dB , while the woofer would be 109 dB at 100 watts, though it is only rated for 60 watts. Since the A500 is rated at 160 watts into 8 ohms, looking for a tweeter amp of similar power at 4 ohms would not be unreasonable if you want to have no clipping on HF transients. Art Welter |
#7 |
yes Art , but the treble portion of a 109 dB music signal would be around 30 % of total power , usually is like that when calculating amp ratios for multi-way .
#8 | |
#9 |
I would not disagree with that ratio (it depends on the xover frequency of course) for a power average, but peak power requires the same power for both high and low if they are of the same sensitivity.
#10 | |
That said, if the SB17NRX35-4 is rated at only 60 watts, it will probably be suffering from around 3 dB power compression if you hit it with many 230 watt peaks, so 115 watts or so of power for the tweeters should be adequate, as with less average power they will not have much thermal compression |
| Tweeter Mount & Diamond Audio Aluminum Tweeter | cnp112 | Car Audio | 0 | 18th November 2010 05:35 AM |
| Electrocompaniet Ampliwire 100 (AW 100 AW100) different Versions | tiefbassuebertr | Solid State | 3 | 2nd September 2009 09:44 AM |
| Tweeter help for Miller & Kreisell Tweeter 17500 | merajsalek | Multi-Way | 4 | 3rd September 2008 03:41 AM |
| Peerless HDT 100 tweeter for Karlson party speaker project | bikehorn | Multi-Way | 6 | 6th February 2006 08:00 AM |
| WTB: One tweeter for Boston A-100 | r0cket- | Swap Meet | 2 | 31st October 2004 06:37 AM |
| Page generated in 0.12092 seconds (79.23% PHP - 20.77% MySQL) with 10 queries |
