I know this is a pretty simple question, but since it's my first pair of speakers, I'd like to know if there are any tricks or things to beware of before screwing in drivers to baffles. I have a mid and a tweeter that I've routed holes for (flush mounted, of course). Is it as straightforward as screwing the drivers in to the MDF? Or are there other steps to take. I'll be drilling pilot holes but is there anything else to do?
#2 |
The most simple is to drill a pilot hole.
The most difficult is to tighten, enough to avoid resonance of the basket and and not too much to avoid to put out of shape the basket. Some people use screws and insert nuts in the wood but i have never used those. You can also add a gasket but i think it is not necessary. Never use a glue mastic ! |
#3 |
If the speaker units do not come with a gasket then I would personally make one out of thin felt so they seal properly. And use cross headed screw so you don't slip and pierce or scratch the driver.
#4 |
Personally I would use T-nuts with MDF. It just doesn't "hold" a thread well. IMO, if you don't install 'em now, you'll be installing 'em later.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#5 |
frugal-phile(tm)
Screws (or bolts) should be tightened just enuff that a real or imaginary washer can't spin. If you are deforming the basket that is way too much torque.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |
frugal-phile(tm)
dave
#7 | |
frugal-phile(tm)
dave
#8 |
Too late! And MDF isn't that bad. It is quite messy, but is really easy to work with, is cheap, and is pretty good acoustically.
The drivers have built in foam gaskets. I like the t nuts idea. I'll fish around in my bolts bin... |
| Screwing into Heatsink - advice needed | mrwireless | Construction Tips | 17 | 15th October 2009 03:57 PM |
| Screwing: Just say no? | brucegseidner | Multi-Way | 25 | 17th July 2009 03:22 AM |
| Newby needs help screwing with a professional design | martyh | Multi-Way | 1 | 8th July 2009 01:11 AM |
| Clipping vs Screwing Down Power Chips | CarlosT | Chip Amps | 34 | 18th December 2006 09:15 PM |
| Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? | thadman | Multi-Way | 7 | 11th November 2006 09:11 PM |
| Page generated in 0.09147 seconds (78.71% PHP - 21.29% MySQL) with 10 queries |
