Manifold Enclosure for bass - diyAudio
Old 24th August 2003, 11:19 PM   #1
BAM is offline BAM
Send a message via AIM to BAM
Default Manifold Enclosure for bass
I have a question. A local church has four Peavey 15" woofers which need bass enclosures so they can go with their PA system as subs. I have seen Electro-Voice PA subwoofers that use a loading technique called a Manifold. Are there any special considerations that need to be made for designing such an enclosure?
Old 25th August 2003, 01:50 AM   #2
GM is offline GM  United States
GM's Avatar
I'm sure there is. Got any pics or details? I know what I consider a manifold, a bunch of drivers firing into a common pipe, but it may not be EV's.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th August 2003, 02:19 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
No special considerations - it is just a vented box. Calculate the volume and port pretty much as usual.
The close proximity of all the drivers may add a bit of loading, so tuning a bit lower to start out could be a good idea, but it depends on what electronics and crossover frequencies you are using and how the response turns out.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 25th August 2003, 04:06 AM   #4
GM's Avatar
OK, I remember these. They're BPs, and for max performance need to be modeled as such since the central cavity dims sets the HF BW/gain/cutoff.
GM
Old 25th August 2003, 07:39 PM   #5
ronc is offline ronc  United States
Is that a sealed center chamber?
ron
Old 25th August 2003, 08:59 PM   #6
GM's Avatar
No, per the shading on the drawing it shows a solid back and open front, creating a 1/4WL vent pipe, and why its depth/area is key to its HF response, etc.. It's a design I've 'cloned' and it works quite well, just didn't know EV called it a manifold. It would be interesting to tweak the design to incorporate a Karlson coupler to increase its HF response high enough to XO to a mid horn.
GM
Old 26th August 2003, 09:53 PM   #7
BAM is offline BAM
I don't see anything like a quarter-wave pipe. All I see is a vented box. Please explain how I am to determine the dimensions of the manifold, if you would.
Bass enclosure for 3 way Dr_EM Multi-Way 65 28th April 2011 01:58 PM
need Manifold 2 x 18 cabinet plans djmarvellous Subwoofers 70 19th March 2011 12:18 AM
Manifold mid bass horn entry??? fredos Subwoofers 0 28th October 2008 10:32 PM
Mid-Horn...EV Manifold technology Samuel Jayaraj Multi-Way 1 17th February 2002 12:15 PM
Copyright 1999-2017 diyAudio
