I'm thinking a waveguide is like a small flare or shallow horn around the drive unit.
For example, if I were to put a shallow (1.5" deep x 2" wide rim) waveguide on a midrange driver of 4-5 inches, would it add a measurable increase in dB ( I am guessing above a frequency range associated with the size of flare)
Cool Loudspeakers Facebook group http://www.facebook.com/media/set/?s...24506880902633 Last edited by Bill poster; 27th July 2011 at 01:32 PM. |
#2 |
Yes, they increase sound levels 2 ways. First they make the driver more directional, at least over some of the frequency range. This increases the on-axis pressure by the change in directivity index (d.i. in dB). This is an axial pressure increase, not a power (over all angles) increase.
Secondly, since the driver is radiating into a smaller solid angle the acoustic load goes up and efficiency improves somewhat. This is a radiated power increase. David S. Last edited by speaker dave; 27th July 2011 at 01:53 PM. |
#3 |
It was explained to me that wave guides are mostly concerned with controlling directivity and horns are all about matching impedance. A wave guide may increase the efficiency of a particular driver, but not nearly as much as a horn does. A horn is an acoustical transformer, matching the acoustical impedance of the free air with that of the driver. A wave guide merely controls the radiating pattern of the driver and doesn't necessarily match impedances.
#4 |
Beware that waveguides are effective in increasing sound level, but not equally at all frequencies. In other words, they change the FR of a driver.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall. |
#5 |
yes I'm quite interested in this aspect ( I need to boost the upper midrange in a design I'm working on).
Cool Loudspeakers Facebook group http://www.facebook.com/media/set/?s...24506880902633 |
#6 |
I've done a lot of directivity flares over the years (my Avatar shows one done at Snell). I tend to use the CD flare from JBL as a wall contour definition.
They must be done experimentally and they will effect the frequency response, but with care you can get a smooth response that works with a crossover and can even get better response than without, as the driver tends to see the cabinet edges less. I've had trouble with deeper (narrow angle) waveguides and totally circular waveguides degrading the frequency response. As with a CD horn the inner dimension determines the upper frequency of pattern control and the outter dimension sets the lowest frequency of pattern control. Read Don Keele's early CD horn papers to understand that. http://www.xlrtechs.com/dbkeele.com/...xp%20Horns.pdf Finally, look at what Genelec has done in their studio monitors. I think they have achieved good results. David S Last edited by speaker dave; 27th July 2011 at 03:50 PM. |
#7 |
Geddes?
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#8 | |
#9 |
Yes?
Its a complicated problem. For a wide waveguide the efficiency increase due to loading is minimal - it all comes from increased directivity. For an ideal waveguide the response from a constant acceleration source (i.e. a driven piston above resonance) the response along any axis will fall at 6 dB/oct, but the power response will fall at the same rate. The same piston without a waveguide would have a flat AXIAL response but the power response would fall. In my waveguides the response at 10kHz is about the same as the response of the same sized unbaffled piston. This means that below 10kHz its response will rise as the frequency falls. So if EQ'd to flat, the displacement will fall below 10Khz at 20 dB/decade giving the waveguide loaded piston a 20 dB advantage in displacement for equal SPL over the unbaffled piston at 1 kHz. |
#10 | |
The only exception would be cancelation notches from symmetry. David S. |
| microphone levels | theChris | Everything Else | 5 | 24th May 2009 07:37 AM |
| Sound levels - weird question! | peter_m | Everything Else | 5 | 15th August 2007 03:36 PM |
| sound card input levels | maylar | Solid State | 3 | 28th April 2004 10:50 AM |
| Increase voltage for better sound.... | Mikka | Solid State | 1 | 18th May 2003 05:23 PM |
| Optimum settings for Computer Sound levels | downhere | Solid State | 5 | 20th December 2001 02:52 AM |
| Page generated in 0.12443 seconds (84.16% PHP - 15.84% MySQL) with 10 queries |
