i like visaton units .....possible sound in a reasonable prize
the question is about this unit Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories i am using this and tryied it in almost 5-6 combination sealed enclosure bass reflex enclosure second order xover second /third order xoover third /fourth order xover played to x over frequencies 2.000 and above and up to 4.300 now the problem is that no matter the enclosure or the xover that actually produced better bass due to the reflex and lower also ...and wonderfull high due to the xover but also the tweeter itshelf in any of the combination there is obvious absense of midle also seems that midle is present but will need some ammout of power to come "up" in low listening levels the midle is quiet poor ...looking at the graph i think that the unit is a wise choise for a two way speaker but still at low listening levels seems that this is a problem any input ?
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
Maybe it's the woofer sound itself, but you can simulated what it does nicely with Boxsim, it includes all Visaton drivers. Boxsim - Homepage
Ultrabarbarium |
#3 |
That's odd that the midrange is lacking, especially considering that the chart for that driver shows a gradual increase in output from 300Hz all the way up to 3kHz, over an 8dB range.
Possibly a dumb question, but you ARE designing the XO for 4 ohms and not 8 ohms, correct? The reason I ask is because you are designing the XO for an 8 ohm driver, the XO point will be only half the desired target on a 4 ohm driver.
Charles |
#4 |
thanks for your input but all my calculation and changes have been made for 8R which actually is the imp. of the woofer
#5 | |
#6 |
Then you linked to the wrong driver.
Charles |
#7 |
Yes on the page are both downloads.
Ultrabarbarium |
#8 |
You are not actually calculating a passive crossover for a real impedance, are you?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#9 |
What size box have you used, and what frequency is it tuned to?
This is a High Q driver, really only suitable for Open Baffle; most sealed and vented boxes, unless huge, will have a large peak at the low end, giving the impression of missing mids....
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#10 | |
BUMP ^^^^^^^^^^^^^^^^^^^^
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. |
| Visaton B200's | NED 209 | Swap Meet | 1 | 6th November 2009 02:42 AM |
| visaton | lejaybo | Multi-Way | 21 | 2nd February 2009 05:24 PM |
| visaton fullrange | resident | Full Range | 9 | 21st November 2004 03:18 PM |
| "Visaton - is it worth?" or... "Share your Visaton experience" | mr_push_pull | Multi-Way | 10 | 7th August 2004 06:18 PM |
| Visaton | shadow | Multi-Way | 6 | 16th June 2002 09:27 AM |
| Page generated in 0.10487 seconds (79.28% PHP - 20.72% MySQL) with 10 queries |
