Old 25th July 2011, 05:37 PM   #1
xtc is offline xtc  Norway
Default Seas MP14RCY and Scanspeak D2905/9000 questions
Hi.
I'm thinking about making a speaker made of the D2905/9000 tweeter and MP14RCY mid range speaker, but I have some questions about the crossover frequencies and network solutions.
Which crossover frequencies should make the network of.
I'm grateful for any advice..
Old 25th July 2011, 06:51 PM   #2
I tend to cut such floppy PP membranes as low as the tweeter can handle as to avoid uneven power response; so in your case probably between 1.5 and 2.5kHz depending on the filter order.
crazyhub
Old 26th July 2011, 08:53 AM   #3
How many liters should the box for the mid range speaker?
Old 26th July 2011, 06:00 PM   #4
power handling depending on the high-pass slope and fr.
Examples:
1.7 liter / closed heavy fill / Qtc 0.56 / F3 169Hz / F1 350hz
if you need some more dbs lower in fr:
2 liters / vented walls covered / 0db tuning peak / Fb 95hz / F3 107hz / F1 170hz / vent dia 3cm length 9.2cm / first port resonance low in spl and high in fr (unaudible)
crazyhub
Old 29th July 2011, 08:44 AM   #5
I have sent you a PM about almost the exact driver combination. Merrimac, a 3-way speaker project from the old magazine Audio used P14RCY. From my recollection it used the standard SEAS midrange box.
WTB : Scan Speak D2905 9000/9300/9500 to France lmtriet Swap Meet 4 5th April 2011 10:29 PM
Scanspeak D2905/9000 tweeters ronjg Swap Meet 1 26th June 2010 06:32 PM
FS: pair Seas MP14RCY midwoofers CharlieLaub Swap Meet 4 17th June 2010 09:21 PM
chamber for seas mp14rcy zach Multi-Way 2 18th August 2001 11:05 AM
Page generated in 0.08373 seconds (76.94% PHP - 23.06% MySQL) with 10 queries
